I don't know the pipers well enough to comment specifically,
but this surely shouldn't be happening. it's a safety of flight issue. The cable should be constrained so it can't slip on the capstain. Sometimes this is done with a bead staked on the cable in the middle of the capstain... it drops down into a small hole in the capstain. There might be other mechanisms to do this, but there will be some way to do this. If the travel isn't well centered, something may collide near the end in one direction or the other. There usually isn't a lot of excess travel available; that is they only use enough wraps to get the job done in the first place. You may want to loosen the bridle cable clamps and reposition them slightly so that travel to each end is the same. The cables should have some tension in them; if they are loose, the autopilot may oscillate. bh On Apr 19, 5:50*pm, "Mike Noel" wrote: My '74 archer developed an intermittent problem where the aileron would have a 'soft stop' at one end of the control throw. *I thought a mechanic might have left a rag or some such under the floor that moved around and sometimes prevented full control deflection, so I removed the floorboard under the back seats. *I found instead that the aileron servo pulley had several wraps of cable and what appears to be a pin stake to keep the cable against the pulley, presumably to prevent the cable from sliding on the pulley. *At one end of throw the pin stops the cable from unwrapping from the pulley and the cable bends down, giving the feel of a soft stop. Anyone familiar with the mechanics of this arrangement? *My best guess is that the cable is actually sliding around the pulley slightly when I help the autopilot in rough air and sometimes the pin is in a position to allow a natural hard stop and at other times it stops the aileron short of full throw. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel |
I pulled the rear floorboard again and tried turning the servo capstan with
a wrench on the center shaft nut. I was able to turn the capstan while the aileron was at the end of its travel, confirming that the cable is able to slip through the cable stake. Will the fix be inserting a new stake tightly enough to keep the cable fixed on the capstan, or perhaps replacing the capstan/cable assembly? Looks like the main trick for the mechanic will be getting the tension correct on the bridle cable. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel " wrote in message ... I don't know the pipers well enough to comment specifically, but this surely shouldn't be happening. it's a safety of flight issue. The cable should be constrained so it can't slip on the capstain. Sometimes this is done with a bead staked on the cable in the middle of the capstain... it drops down into a small hole in the capstain. There might be other mechanisms to do this, but there will be some way to do this. If the travel isn't well centered, something may collide near the end in one direction or the other. There usually isn't a lot of excess travel available; that is they only use enough wraps to get the job done in the first place. You may want to loosen the bridle cable clamps and reposition them slightly so that travel to each end is the same. The cables should have some tension in them; if they are loose, the autopilot may oscillate. bh On Apr 19, 5:50 pm, "Mike Noel" wrote: My '74 archer developed an intermittent problem where the aileron would have a 'soft stop' at one end of the control throw. I thought a mechanic might have left a rag or some such under the floor that moved around and sometimes prevented full control deflection, so I removed the floorboard under the back seats. I found instead that the aileron servo pulley had several wraps of cable and what appears to be a pin stake to keep the cable against the pulley, presumably to prevent the cable from sliding on the pulley. At one end of throw the pin stops the cable from unwrapping from the pulley and the cable bends down, giving the feel of a soft stop. Anyone familiar with the mechanics of this arrangement? My best guess is that the cable is actually sliding around the pulley slightly when I help the autopilot in rough air and sometimes the pin is in a position to allow a natural hard stop and at other times it stops the aileron short of full throw. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel |
On Apr 21, 7:31*pm, "Mike Noel" wrote:
I pulled the rear floorboard again and tried turning the servo capstan with a wrench on the center shaft nut. *I was able to turn the capstan while the aileron was at the end of its travel, confirming that the cable is able to slip through the cable stake. *Will the fix be inserting a new stake tightly enough to keep the cable fixed on the capstan, or perhaps replacing the capstan/cable assembly? *Looks like the main trick for the mechanic will be getting the tension correct on the bridle cable. Buy turning with a wrench, you might not be getting the answer you think. Generally there will be a safety clutch between the shaft of the motor and the capstan. So if you turn the shaft and the ailerons have hit their stop, you will be slipping the clutch. So you need to see if the cables move relative to the capstan. Bill Hle |
Bill, in this case I could see the capstan slipping under the cable.
Evidently the cable could slip on the capstan easier than the capstan could slip on the clutch. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel " wrote in message ... On Apr 21, 7:31 pm, "Mike Noel" wrote: I pulled the rear floorboard again and tried turning the servo capstan with a wrench on the center shaft nut. I was able to turn the capstan while the aileron was at the end of its travel, confirming that the cable is able to slip through the cable stake. Will the fix be inserting a new stake tightly enough to keep the cable fixed on the capstan, or perhaps replacing the capstan/cable assembly? Looks like the main trick for the mechanic will be getting the tension correct on the bridle cable. Buy turning with a wrench, you might not be getting the answer you think. Generally there will be a safety clutch between the shaft of the motor and the capstan. So if you turn the shaft and the ailerons have hit their stop, you will be slipping the clutch. So you need to see if the cables move relative to the capstan. Bill Hle |
A Service ceiling question (Piper 235) | falcon | Piloting | 0 | December 6th 04 10:28 PM |
Piper PA-28 question | GE | Owning | 14 | September 21st 04 12:02 AM |
A/D Question for Piper Cherokees | zatatime | Owning | 6 | June 11th 04 01:43 AM |
Piper Autocontrol IIIB | PaulaJay1 | Owning | 8 | January 16th 04 09:43 PM |
Autocontrol IIIB | PaulaJay1 | Owning | 13 | October 24th 03 02:39 PM |
