On Apr 21, 7:31*pm, "Mike Noel" wrote:
I pulled the rear floorboard again and tried turning the servo capstan with a wrench on the center shaft nut. *I was able to turn the capstan while the aileron was at the end of its travel, confirming that the cable is able to slip through the cable stake. *Will the fix be inserting a new stake tightly enough to keep the cable fixed on the capstan, or perhaps replacing the capstan/cable assembly? *Looks like the main trick for the mechanic will be getting the tension correct on the bridle cable. Buy turning with a wrench, you might not be getting the answer you think. Generally there will be a safety clutch between the shaft of the motor and the capstan. So if you turn the shaft and the ailerons have hit their stop, you will be slipping the clutch. So you need to see if the cables move relative to the capstan. Bill Hle |
Bill, in this case I could see the capstan slipping under the cable.
Evidently the cable could slip on the capstan easier than the capstan could slip on the clutch. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel " wrote in message ... On Apr 21, 7:31 pm, "Mike Noel" wrote: I pulled the rear floorboard again and tried turning the servo capstan with a wrench on the center shaft nut. I was able to turn the capstan while the aileron was at the end of its travel, confirming that the cable is able to slip through the cable stake. Will the fix be inserting a new stake tightly enough to keep the cable fixed on the capstan, or perhaps replacing the capstan/cable assembly? Looks like the main trick for the mechanic will be getting the tension correct on the bridle cable. Buy turning with a wrench, you might not be getting the answer you think. Generally there will be a safety clutch between the shaft of the motor and the capstan. So if you turn the shaft and the ailerons have hit their stop, you will be slipping the clutch. So you need to see if the cables move relative to the capstan. Bill Hle |
A Service ceiling question (Piper 235) | falcon | Piloting | 0 | December 6th 04 10:28 PM |
Piper PA-28 question | GE | Owning | 14 | September 21st 04 12:02 AM |
A/D Question for Piper Cherokees | zatatime | Owning | 6 | June 11th 04 01:43 AM |
Piper Autocontrol IIIB | PaulaJay1 | Owning | 8 | January 16th 04 09:43 PM |
Autocontrol IIIB | PaulaJay1 | Owning | 13 | October 24th 03 02:39 PM |
