![]() "Highflyer" wrote No problem. Use the next size larger tubing. Run it through the bandsaw lengthwise. Fix it over the damaged tube and weld everything back together. How about cutting a taper (like points on opposite sides from each other) on the new tube to avoid creating a stress riser that would occur where the new tube suddenly stopped, all of the way around? -- Jim in NC |
On Sun, 27 Jul 2008 23:04:01 -0400, "Morgans"
wrote: "Highflyer" wrote No problem. Use the next size larger tubing. Run it through the bandsaw lengthwise. Fix it over the damaged tube and weld everything back together. How about cutting a taper (like points on opposite sides from each other) on the new tube to avoid creating a stress riser that would occur where the new tube suddenly stopped, all of the way around? As posted before, required. ** Posted from http://www.teranews.com ** |
![]() clare at snyder dot ontario dot canada wrote As posted before, required. I musta missed that. Highflyer left that part out, and I wanted to make sure that was understood. -- Jim in NC |
Stressed Skin Repair Question | RPM the A&P | Home Built | 9 | July 16th 08 04:59 AM |
4130 can't be OA welded? | wright1902glider | Home Built | 61 | January 4th 08 05:19 AM |
Magneto Repair vs Overhaul Question. | Ebby | Home Built | 6 | February 24th 07 05:55 PM |
172 Repair question | Brad Mallard | Home Built | 2 | June 11th 04 02:54 AM |
172 Repair question | Brad Mallard | Aviation Marketplace | 3 | June 11th 04 02:54 AM |
