Nomen Nescio wrote in
: -----BEGIN PGP SIGNED MESSAGE----- From: "Viperdoc" The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? 1) It's AVIATION 2) Nitrogen is more expensive Asked a grease monkey friend there a few minutes ago. He says that O2 under pressure is considerably more reactive than it is at normal atmospheric pressures. So the main reason is to prevent oxidation of tires and seals. A secondary consideation is detonation in oleos. Bertie |
Bertie:
I find this hard to swallow, and I doubt that oxygen (at 20% of air), regardless of pressure, is going to cause a detonation in an oleo. Just like in a tire, the percentage of oxygen remains the same, so its ability to support combustion also remains the same. Now, the increased oxygen pressure might slightly increase the risk of corrosion, but we are not talking orders of magnitude higher compared to ambient. At least this is my understanding as I recall from being a chemistry undergrad and grad student. The more I hear about this, the more I think it's an old wive's tale. Anway, what did you think of Anthony's claim"it's not me?" What a moron. |
"Viperdoc" wrote in
: Bertie: I find this hard to swallow, and I doubt that oxygen (at 20% of air), regardless of pressure, is going to cause a detonation in an oleo. Our oleos are a little more, eh, enthusiastic shall we say, than the oleo on a cherokee! Thumping a hypothetical airplane that weighs, say 500,000 lbs onto an oleo strut of about a foot in dia at, maybe over 1,000 fpm rate of descent is going to get things pretty exciting inside the strut.I have no idea what the compression ratio is in there, but it's got to be reasonably high. I do come across one grease monkey who has answers galore. Anything he doesn't know he finds out for me the next time I'm through. He's just one of these guys with an insatiable curiosity about all things mechanical.. Just like in a tire, the percentage of oxygen remains the same, so its ability to support combustion also remains the same. Now, the increased oxygen pressure might slightly increase the risk of corrosion, but we are not talking orders of magnitude higher compared to ambient. At least this is my understanding as I recall from being a chemistry undergrad and grad student. Apparenlty, the increased prsssure makes O2 much more aggresive so the effect is not slight, but in any case, I'm only telling you what my bud said and he's quality control for a big airline. The more I hear about this, the more I think it's an old wive's tale. Anway, what did you think of Anthony's claim"it's not me?" What a moron. Oh yeh. Couldn't care less if it's him or not, to be honest! Bertie |
"Viperdoc" wrote in message
... Bertie: I find this hard to swallow, and I doubt that oxygen (at 20% of air), regardless of pressure, is going to cause a detonation in an oleo. Just like in a tire, the percentage of oxygen remains the same, so its ability to support combustion also remains the same. Now, the increased oxygen pressure might slightly increase the risk of corrosion, but we are not talking orders of magnitude higher compared to ambient. At least this is my understanding as I recall from being a chemistry undergrad and grad student. The more I hear about this, the more I think it's an old wive's tale. Anway, what did you think of Anthony's claim"it's not me?" What a moron. About all that I know on the reactivity subject is by inferance from the assertion that our own need for suplemental oxygen at altitude is based on partial pressure. On that basis, it seems to make a sort of sense, even though it would require a *lot* of pressure and might also require the oil in the strut to be partially vaporized--possibly during the early stages of the rebound after the struts were vigorously compressed. In the case of light plane tires, I agree with you that really dry air should work well enough to make the issue trivial. But, if you need nitrogen for any other reason, it is the cheapest thing that I know of in an L bottle or larger and using it in the tires may be essentially free--because you may have to pay rental on the tanks if they are not refilled at a prescribed interval. Peter |
"Peter Dohm" wrote in
: In the case of light plane tires, I agree with you that really dry air should work well enough to make the issue trivial. But, if you need nitrogen for any other reason, it is the cheapest thing that I know of in an L bottle or larger and using it in the tires may be essentially free--because you may have to pay rental on the tanks if they are not refilled at a prescribed interval. My daughter is a Crew Chief on a C-130 Herc and said that Nitrogen is used in the struts. -- |
"John Godwin" wrote in message
... "Peter Dohm" wrote in : In the case of light plane tires, I agree with you that really dry air should work well enough to make the issue trivial. But, if you need nitrogen for any other reason, it is the cheapest thing that I know of in an L bottle or larger and using it in the tires may be essentially free--because you may have to pay rental on the tanks if they are not refilled at a prescribed interval. My daughter is a Crew Chief on a C-130 Herc and said that Nitrogen is used in the struts. -- I'm sure that they use nitrogen in the tires as well--even though they run at less than half of the pressure of a lot of the heavy jets--it just makes sense to use it when you have it available. Getting back to the original subject of whether nitrogen behaves in a manner more like an "ideal gas" than air, aside from the issue of reactivity, the answer is yes--especially as pressure is increased and/or temperature is decreased. Basically, it is relatively easy to have nitrogen that is extremely dry because it it normally dispensed from the top of a very high pressure storage bottle--with the result that nearly all of any water vapor and/or CO2 that is in the bottle will be left in a condensed form at the bottom of the bottle. |
John Godwin wrote in news:Xns9B1BD7A3321FBAvSvcs@
208.49.82.60: "Peter Dohm" wrote in : In the case of light plane tires, I agree with you that really dry air should work well enough to make the issue trivial. But, if you need nitrogen for any other reason, it is the cheapest thing that I know of in an L bottle or larger and using it in the tires may be essentially free--because you may have to pay rental on the tanks if they are not refilled at a prescribed interval. My daughter is a Crew Chief on a C-130 Herc and said that Nitrogen is used in the struts. Your daughter smokes cigars? Bertie |
![]() "Bertie the Bunyip" wrote in message ... John Godwin wrote in news:Xns9B1BD7A3321FBAvSvcs@ 208.49.82.60: "Peter Dohm" wrote in : In the case of light plane tires, I agree with you that really dry air should work well enough to make the issue trivial. But, if you need nitrogen for any other reason, it is the cheapest thing that I know of in an L bottle or larger and using it in the tires may be essentially free--because you may have to pay rental on the tanks if they are not refilled at a prescribed interval. My daughter is a Crew Chief on a C-130 Herc and said that Nitrogen is used in the struts. Your daughter smokes cigars? Bertie You're a dumb ass. |
Tire inflation with Nitrogen or ? | [email protected] | Home Built | 52 | April 29th 07 04:49 AM |
Filling with nitrogen | scott moore | Owning | 21 | December 8th 06 07:48 PM |
172 Nosewheel Struts Leak Nitrogen | jls | Owning | 4 | April 9th 04 06:28 PM |
