Why nitrogen?
Old September 17th 08, 05:11 AM posted to rec.aviation.piloting
John Godwin
Default Why nitrogen?
"Peter Dohm" wrote in
In the case of light plane tires, I agree with you that really dry
air should work well enough to make the issue trivial. But, if
you need nitrogen for any other reason, it is the cheapest thing
that I know of in an L bottle or larger and using it in the tires
may be essentially free--because you may have to pay rental on the
tanks if they are not refilled at a prescribed interval.
My daughter is a Crew Chief on a C-130 Herc and said that Nitrogen is
used in the struts.
Old September 17th 08, 09:55 PM posted to rec.aviation.piloting
Peter Dohm
"John Godwin" wrote in message
used in the struts.
I'm sure that they use nitrogen in the tires as well--even though they run
at less than half of the pressure of a lot of the heavy jets--it just makes
sense to use it when you have it available.
Getting back to the original subject of whether nitrogen behaves in a manner
more like an "ideal gas" than air, aside from the issue of reactivity, the
answer is yes--especially as pressure is increased and/or temperature is
decreased. Basically, it is relatively easy to have nitrogen that is
extremely dry because it it normally dispensed from the top of a very high
pressure storage bottle--with the result that nearly all of any water vapor
and/or CO2 that is in the bottle will be left in a condensed form at the
bottom of the bottle.
Old September 17th 08, 10:27 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
John Godwin wrote in news:Xns9B1BD7A3321FBAvSvcs@
208.49.82.60:
used in the struts.
Your daughter smokes cigars?
Bertie
Old September 18th 08, 12:41 AM posted to rec.aviation.piloting
Mick[_2_]
208.49.82.60:
used in the struts.
Bertie
You're a dumb ass.
Old September 18th 08, 12:45 AM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
"Mick" @_#`~#@.^net wrote in :
news:Xns9B1BD7A3321FBAvSvcs@ 208.49.82.60:
is used in the struts.
Bertie
You're a dumb ass.
Nope.
Bertie
Old September 18th 08, 10:01 PM posted to rec.aviation.piloting
Mick[_2_]
Bertie
You're a dumb ass.
Nope.
Bertie
You're a cross posting dumb ass.
Tire inflation with Nitrogen or ? [email protected] Home Built 52 April 29th 07 04:49 AM
Filling with nitrogen scott moore Owning 21 December 8th 06 07:48 PM
172 Nosewheel Struts Leak Nitrogen jls Owning 4 April 9th 04 06:28 PM
