![]() "Morgans" wrote in message ... "Peter Dohm" wrote It appears that they were lucky and the oxygen was'nt needed; but it does remind me of some of the speculation surrunding the Paine Stewart case. Two hypotheses around my local airport were that 1) the tank was inadvertantly filled with nitrogen or 2) that someone misread the labeling on the regulator on/off handle--which is counterintuitively labeled with "on" or "off" and arrows pointing which direction to turn the knob for the desired result. I don't recall whether the case was ever fully resolved; but a lot of pilots found a couple of areas worthy of their maximum vigilance! Learjets don't use bottled oxygen; they have pressurized air from the engines. -- Jim in NC Learjets do indeed use bottled oxygen and it is found in the nose bay area. There is a thin capillary that runs into the cockpit to a pressure gauge. The pressure gauge displays the pressure in the tank regardless of whether the valve is turned on or off. The pressure in the tank can read full on the ground but at low temperature at altitude will read several hundred pounds less. -- *H. Allen Smith* WACO - We are all here, because we are not all there. |
![]() "Allen" wrote Learjets do indeed use bottled oxygen and it is found in the nose bay area. There is a thin capillary that runs into the cockpit to a pressure gauge. The pressure gauge displays the pressure in the tank regardless of whether the valve is turned on or off. The pressure in the tank can read full on the ground but at low temperature at altitude will read several hundred pounds less. They do? For primary breathing air at altitude? Is there no cabin air pressurization provided by bleed air from the engines? I'm not doubting your word, just trying to understand. I thought all bizjets used bleed air to pressurize the cabins. -- Jim in NC |
... "Allen" wrote Learjets do indeed use bottled oxygen and it is found in the nose bay area. There is a thin capillary that runs into the cockpit to a pressure gauge. The pressure gauge displays the pressure in the tank regardless of whether the valve is turned on or off. The pressure in the tank can read full on the ground but at low temperature at altitude will read several hundred pounds less. They do? For primary breathing air at altitude? Is there no cabin air pressurization provided by bleed air from the engines? I'm not doubting your word, just trying to understand. I thought all bizjets used bleed air to pressurize the cabins. -- Jim in NC All the business jets I know of do use bleed air for cabin pressurization, and have oxygen bottles for emergency when you have a cabin pressure failure. You only need enough oxygen to get you down to 10k feet. It would be nice to be conscious during this phase. -- Regards, Bob F. |
"Morgans" wrote in
: "Allen" wrote Learjets do indeed use bottled oxygen and it is found in the nose bay area. There is a thin capillary that runs into the cockpit to a pressure gauge. The pressure gauge displays the pressure in the tank regardless of whether the valve is turned on or off. The pressure in the tank can read full on the ground but at low temperature at altitude will read several hundred pounds less. They do? For primary breathing air at altitude? Is there no cabin air pressurization provided by bleed air from the engines? I'm not doubting your word, just trying to understand. I thought all bizjets used bleed air to pressurize the cabins. They do you idiot. Loss of pressurisation was being discussed. Learn to read... Bertie |
![]() "Bertie the Bunyip" wrote in message ... Learn to read... Bertie Why you can't. |
"Mick" @_#`~#@.^net wrote in :
"Bertie the Bunyip" wrote in message ... Learn to read... Bertie Why you can't. And you might learn to write. Bertie |
![]() "Bertie the Bunyip" wrote in message ... "Mick" @_#`~#@.^net wrote in : "Bertie the Bunyip" wrote in message ... Learn to read... Bertie Why you can't. And you might learn to write. Bertie Why you can't. |
"Bertie the Bunyip" wrote in message ... "Mick" @_#`~#@.^net wrote in : "Bertie the Bunyip" wrote in message ... Learn to read... Bertie Why you can't. And you might learn to write. Bertie Why you can't. Yeh. You really don't realise what you're saying here, do you, illiterate boi? Bertie |
![]() "Morgans" wrote in message ... "Allen" wrote Learjets do indeed use bottled oxygen and it is found in the nose bay area. There is a thin capillary that runs into the cockpit to a pressure gauge. The pressure gauge displays the pressure in the tank regardless of whether the valve is turned on or off. The pressure in the tank can read full on the ground but at low temperature at altitude will read several hundred pounds less. They do? For primary breathing air at altitude? Is there no cabin air pressurization provided by bleed air from the engines? I'm not doubting your word, just trying to understand. I thought all bizjets used bleed air to pressurize the cabins. -- Jim in NC I am sorry Jim, the O2 is for emergency use. The cabin is pressurized from engine bleed air. The O2 masks drop from the ceiling at 14K' cabin altitude just like the airliners. -- *H. Allen Smith* WACO - We are all here, because we are not all there. |
![]() "Allen" wrote I am sorry Jim, the O2 is for emergency use. The cabin is pressurized from engine bleed air. The O2 masks drop from the ceiling at 14K' cabin altitude just like the airliners. Yep, that's what I thought. Sorry you misunderstood me, and I misunderstood you. This went back to the possibility of oxy causing the Payne Stewart crash, when I replied it was not likely because that was believed to be a primary pressurization problem. -- Jim in NC |
Tire inflation with Nitrogen or ? | [email protected] | Home Built | 52 | April 29th 07 04:49 AM |
Filling with nitrogen | scott moore | Owning | 21 | December 8th 06 07:48 PM |
172 Nosewheel Struts Leak Nitrogen | jls | Owning | 4 | April 9th 04 06:28 PM |
