Basic question
Old February 13th 09, 07:19 PM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
Default Basic question
cavelamb wrote:
Orval Fairbairn wrote:
In article
As I have only ever flown Cessnas, I have a basic question. When
flying a stick plane like an RV-7. What hand do people fly with? On
a yoke I generally used 2 but if I had to use one to do something else
I would keep the left on the yoke. However, I don't know how
comfortable I would feel flying exclusively with the left hand on a
stick. I ask as I am playing on flight simulator and would prefer to
learn how it is actually done. If I have to learn to use the left
hand I will.
Thanks
Barry
Either hand works equally well. I have a 2-plc side-by-side and fly with
left hand on stick, right hand on throttle. Some of my friends fly their
SX-300s from the right seat.
The AF Academy had their TG-14 Ximango motor gliders set up with the PIC
in the right seat, so the stick and throttle configuration resembles
that of fighters.
The big things to remember when transitioning up to an RV-7 (moreso with
a Glasair) a
1. You fly them with your fingertips/toe tips, by pressure, not control
movement
2. You have to plan much further ahead of the plane, as things go by
three times as fast.
3. You will realize that the Cessnas/Pipers, Beeches handle like trucks,
compared to your homebuilt.
3. Continued
If all you have ever flown is Cessna and Piper (stable airplanes) your
homebuilt will feel totally squirrelly - until you get used to it.
THEN the spam cans will handle like trucks...
Actually, the homebuilts are stable -- it is just the controls that are
much lighter.
The early B35 Bonanzas had nice controls, but got heave about in the
1960s. I guess that too many pilots got into trouble when they went VFR
into IFR conditions and needed heavy feel to tell them that they were
maneuvering too hard.
Remove _'s from email address to talk to me.
Old February 13th 09, 07:41 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
In article
hand I will.
Thanks
Barry
that of fighters.
a Glasair) a
movement
3. Continued
much lighter.
Most of the higher performance homebuilts that I've flown are the same.
The controls load up at high speeds.
At least the Tailwind and T-18 did...
But at low speeds they are both light as a feather.
Basic battery charging question [email protected] Soaring 28 April 10th 06 03:12 PM
Basic Training Gliders Justin Craig Soaring 0 December 6th 05 10:08 PM
Basic Training Gliders Justin Craig Soaring 0 December 6th 05 10:07 PM
basic spar construction Dave Schneider Home Built 29 December 30th 04 02:07 PM
A very basic question Ramapriya Piloting 45 November 9th 04 01:57 PM
