Glider Tail Stall
Old February 20th 09, 06:51 PM posted to rec.aviation.soaring
[email protected][_2_]
Default Glider Tail Stall
To add to the confusion:
Many modern gliders are elevator limited - full aft stick just won't
result in enough AOA to stall the wing. Nothing to do with the tail
being stalled. In fact, it's "lifting" just fine, just in the "down"
direction (which could be up if you are at the top of a loop). If the
tail did actually stall, you would get a brisk nose down pitch rate, I
would think! It would be almost the same as the horizontal tail
falling off. Think about it....
Also, the tail on modern gliders do not always push "down". Depends
on speed, AOA, G-load, CG location, flap position, etc. You have to
look at the entire lifting contributions of all the parts of the
glider. Stability is due more to decalage. Look it up.
It's amazing how little most pilots know about how their aircraft
really work....including yours truly!
Kirk
66
Old February 20th 09, 08:08 PM posted to rec.aviation.soaring
Just remembered that there is a good discussion about glider-induced
towplane tailstalls - both horizontal and vertical - in the BGA
towplane manual. The rudder one kinda sounds like fun, actually, as
long as I had a parachute and lots of altitude!
Sorry, no link, I'll try to find it and post later.
kirk
66
Secondary Stall w3n-a Aviation Marketplace 3 December 10th 08 12:36 PM
Stall Characteristics w3n-a Home Built 0 December 4th 08 02:45 PM
Glider Stall Spin Video on YouTube ContestID67 Soaring 13 July 5th 07 08:56 AM
Stall Recovery Danny Deger Piloting 12 January 30th 07 01:01 AM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
