"John R Weiss" wrote:
"Gord Beaman" wrote... Dunno about smart but yes the 'hole' is indeed 3 or 4 inches wide (and there's two usually) but they're not wide open all the time (only when 'dump' is selected). They have another valve portion which mates with them and regulates the 'outflow' to regulate the cabin pressure which controls the 'cabin altitude'. On the 747 the outflow valves that regulate cabin pressure are about 1 x 3 feet, and there are 2 of them. Normal opening is in the range of 12-19%, or about 103-164 square inches. A .40 cal bullet has a cross-sectional area of about 0.126 square inches, or about 1/1000 of the normal outflow area. Even a full pax window, at about 6x8 inches, has less area. Though it would be noisy and breezy if a window disintegrated (until a serving tray or something got stuck in it), rapid depressurization would not occur, as the outflow valves would adjust over the course of about 2 seconds. Of course, the size of the outflow valves in smaller airplanes would be somewhat smaller, but the net result would be similar. I agree...the size of valves that I quoted belong to a Convair 580...VERY much smaller than a 747, but I'm still surprised by how large the 747 ones are. Anyhow, I agree with you about the outflow valve compensating for a blown out window. Pretty well a 'nonevent' as far as disaster is concerned. -- -Gord. |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 7 | November 6th 04 08:34 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
Vacuum pressure | Peter MacPherson | Instrument Flight Rules | 1 | May 30th 04 04:01 PM |
Greatest Altitude without pressure cabin/suit | W. D. Allen Sr. | Military Aviation | 12 | July 26th 03 04:42 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
