Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will NeedFixes
Old March 26th 09, 11:44 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Peter Skelton
Default Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will Need Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will Need
On Thu, 26 Mar 2009 02:56:45 -0700 (PDT), Jack Linthicum
On Mar 26, 3:58*am, Kerryn Offord wrote:
Matt Wiser wrote:
Then explain its record in Iraq and Afghanistan so far. No combat losses or
crashes in-country. Like I said, if you have an alternative platform to
replace the H-46s, let's hear it. Otherwise, either get on board or get out
of the way.
doing what kind of operations at what kind of tempo..
last we heard (SMN) it was doing the mail runs.. and running through
their engines at a high rate of knots...
As for alternatives.. any number of proper helicopters... Things that
can carry the same cargo with a third of the power requirements.. And
can fly quite easily with a slung load... (If the V-22 fly with a slung
load you'd be better off using helicopters... they're only any good if
you can fly with internal cargo only.. and even then it gets a bit
cramped....
First crash with real troops on board and it gets on the "history"
list. One of the concepts of the V-22 was its ability to switch from
vertical to horizontal. The loose bolts seem to suggest that might not
work every time.
April 8, 2000
Peter Skelton
KX-99 antenna BNC loose [email protected] Owning 1 April 10th 08 04:26 PM
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" Mike[_7_] Naval Aviation 50 November 30th 07 05:25 AM
Seaplane Base - 4 - Cut Him Loose-3.jpg (1/1) john smith[_2_] Aviation Photos 0 August 2nd 07 05:11 AM
I met US Navy aircraft during Iran-Iraq war Amir - Iranian F-4 pilot Naval Aviation 0 July 29th 07 08:02 PM
Metric Aircraft Nuts and Bolts John Scott Soaring 6 December 14th 05 08:54 PM
