On Mar 26, 2:17*pm, Matt Wiser wrote:
On Mar 26, 8:11*am, Vincent Brannigan wrote: Curt wrote: "Vincent Brannigan" wrote in message ... vaughn wrote: "Jack Linthicum" wrote in message ... Compromising control of the rotor sounds like a fatal crash to me. I have seen *military blogs that say that all of the production must be finished and accepted before the first major *accident can occur. Wishing or making sure? This is the type of stuff that happens with any new aircraft. *We *"learn by doing". *With something as complex and as "different" as the Osprey, we will probably see a significant list of these issues. *And yes, some of them will probably cause accidents before the learning is all over. Vaughn "new" *? *any idea how long this sucker has been teething? First flight was 19 March 1989 20 years ago !!!!!!!!!!!!!!!!!!!!! Keep making excuses for the turkey Vince I guess this means the C-130 a turkey as well. *'course, it's only been flying since 1956. "Inspections of C-130 Hercules cargo aircraft *... are turning up cracks in the nuts and bolts used to attach the wings to the planes' fuselages. The order to inspect the fleet came late Thursday after cracks were found in some upper wing joint barrel *nuts. As a result, the U.S. Air Force has ordered that every C-130 in the nation's 600-plane fleet be checked, which includes the older..." the *suggestion was that this was a "This is the type of stuff that happens with any new aircraft" The C 130 is a quality control issue with a part "Concerns surfaced March 5 about a particular brand of upper wing joint barrel nuts used in C-130s to attach the wings to the fuselage. * The barrel nuts supplied by one manufacturer were deemed "suspect" * after routine inspections discovered a potential for stress fractures * in the metal. As a result, the Pentagon mandated a fleetwide * inspection of each plane's 26 barrel nuts and replacement of all nuts * with the faulty design before the planes could fly again." The V-22 Loose bolts are either a maintenance screw up or a design problem Vince- Hide quoted text - - Show quoted text - Most likely the former. They're still finding occasional issues with C-130s, P-3s, F/A-18s, etc. If you've got an existing helo that can match the range, performance, and other requirements that the V-22 meets, name it. Otherwise, get on board or get out of the way. Might recommend getting out of the way, V-22's greatest quality is speed, an overrated quality in a combat situation. |
KX-99 antenna BNC loose | [email protected] | Owning | 1 | April 10th 08 04:26 PM |
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" | Mike[_7_] | Naval Aviation | 50 | November 30th 07 05:25 AM |
Seaplane Base - 4 - Cut Him Loose-3.jpg (1/1) | john smith[_2_] | Aviation Photos | 0 | August 2nd 07 05:11 AM |
I met US Navy aircraft during Iran-Iraq war | Amir - Iranian F-4 pilot | Naval Aviation | 0 | July 29th 07 08:02 PM |
Metric Aircraft Nuts and Bolts | John Scott | Soaring | 6 | December 14th 05 08:54 PM |
