On Sat, 25 Jul 2009 04:55:46 -0700 (PDT), D Ramapriya wrote:
On Jul 25, 12:16*pm, Clark wrote: 1.3Vso is recommended for approach. It isn't a FAR reg as far as I know. That said, it is standard procedure to land a single engine aircraft at/about Vso. Landing is simply rounding out the descent and then holding the aircraft off the ground +/- 1 foot until it quits flying. It is much easier to type the description than to execute it. Anyway, the stall warning should be on when the wheels touch. In my aircraft, the stall warning activates about 10 kts above stall so it is frequently on in the round out. Look at it from the other side. If the aircraft is above Vso at touch down then the aircraft is much more likely to bounce. Bounces are very bad since they tend to lead to a nose low attitude and damage to the aircraft. If you always touchdown at or slightly below Vso then you won't bounce. Perhaps the part that bothers you is the approach is flown at 1.3Vso and the landing is at Vso. My bad actually - I mistook the approach speed for touchdown speed! I'm not a pilot and it shows ![]() Thanks a lot, Ramapriya You ask good questions though. |
On Jul 25, 10:25*am, Gezellig wrote:
On Sat, 25 Jul 2009 04:55:46 -0700 (PDT), D Ramapriya wrote: On Jul 25, 12:16*pm, Clark wrote: 1.3Vso is recommended for approach. It isn't a FAR reg as far as I know. That said, it is standard procedure to land a single engine aircraft at/about Vso. Landing is simply rounding out the descent and then holding the aircraft off the ground +/- 1 foot until it quits flying. It is much easier to type the description than to execute it. Anyway, the stall warning should be on when the wheels touch. In my aircraft, the stall warning activates about 10 kts above stall so it is frequently on in the round out. Look at it from the other side. If the aircraft is above Vso at touch down then the aircraft is much more likely to bounce. Bounces are very bad since they tend to lead to a nose low attitude and damage to the aircraft. If you always touchdown at or slightly below Vso then you won't bounce. Perhaps the part that bothers you is the approach is flown at 1.3Vso and the landing is at Vso. My bad actually - I mistook the approach speed for touchdown speed! I'm not a pilot and it shows ![]() Thanks a lot, Ramapriya You ask good questions though. Agree! Especially when it makes me think "back to basics" and keeps me from taking things for granted. |
On Sat, 25 Jul 2009 14:45:05 -0700 (PDT), BeechSundowner wrote:
On Jul 25, 10:25*am, Gezellig wrote: On Sat, 25 Jul 2009 04:55:46 -0700 (PDT), D Ramapriya wrote: On Jul 25, 12:16*pm, Clark wrote: 1.3Vso is recommended for approach. It isn't a FAR reg as far as I know. That said, it is standard procedure to land a single engine aircraft at/about Vso. Landing is simply rounding out the descent and then holding the aircraft off the ground +/- 1 foot until it quits flying. It is much easier to type the description than to execute it. Anyway, the stall warning should be on when the wheels touch. In my aircraft, the stall warning activates about 10 kts above stall so it is frequently on in the round out. Look at it from the other side. If the aircraft is above Vso at touch down then the aircraft is much more likely to bounce. Bounces are very bad since they tend to lead to a nose low attitude and damage to the aircraft. If you always touchdown at or slightly below Vso then you won't bounce. Perhaps the part that bothers you is the approach is flown at 1.3Vso and the landing is at Vso. My bad actually - I mistook the approach speed for touchdown speed! I'm not a pilot and it shows ![]() Thanks a lot, Ramapriya You ask good questions though. Agree! Especially when it makes me think "back to basics" and keeps me from taking things for granted. Which you demonstrated by performing your checklists by the book. |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
FSX startup bug | Charles O'Flynn | Simulators | 1 | January 6th 07 06:48 PM |
Oil smoke on startup | Gyroplanes | Rotorcraft | 0 | November 10th 04 04:26 PM |
Don't skip that runup! | Roger Long | Piloting | 8 | July 8th 04 07:04 PM |
Running runup? | G. Burkhart | Piloting | 39 | July 7th 04 11:25 AM |
