FSX startup bug
Old January 6th 07, 06:19 PM posted to rec.aviation.simulators
Charles O'Flynn
Default FSX startup bug
I've just bought and installed MS Flight SimX and am beginning to regret it.
It refuses to load, complaining that the MSXML component is missing and I
should re-install FSX. OK, I thought, why didn't it just load it when it
was installed? Nevertheless, I found MSXML SP2, installed that and guess
what? Same message as before with the MSXML SP2 component missing.
Analysing what has happened, I think that FSX doesn't like to, (or cannot),
co-exist with MSXML - the error message is confusing and incorrect.
Sadly, uninstalling MSXML hasn't so far helped. Has anyone else seen this
and got a solution?
Thanks in advance,
Charles
Old January 6th 07, 07:48 PM posted to rec.aviation.simulators
Contumeliorus Florius
and got a solution?
Thanks in advance,
Charles
This group is pretty much dead. You will get a better resoponse in
'microsoft.public.simulators'. I can't help you as I am not about to waste
my money on FSX.
engine startup problem Frank Ch. Eigler Owning 12 June 4th 05 07:00 PM
Oil smoke on startup Gyroplanes Rotorcraft 0 November 10th 04 05:26 PM
STec-30 doesn't pass startup test after I shorted something.... Dave Owning 12 January 18th 04 06:47 AM
Rick Stitt strikes again... Please Read. Dennis Chitwood Rotorcraft 13 January 10th 04 06:29 PM
Cessna 172K Hawk XP startup procedure? Andrew Boyd Owning 1 July 7th 03 02:40 AM
