On Jan 11, 8:06*am, Tony wrote:
On Jan 11, 9:10*am, Artiom M wrote: Many thanks for answers guys! Finally I understand how to do that. It seem to me the best idea is to cut a board and use a bubble level. Sounds great and easy to do! Thanks Paul! BR. Artiom. p.s. One more question... As English is not my native language can you describe in other words what “boom” means? As I understand this is a Pipe (part of fuselage from end of the wings to tail)? Am I right? ![]() On 11 Sau, 15:09, "Paul Remde" wrote: Hi Artiom, Good question. *It is a ratio. *For every 100 units (inches, mm, whatever) of horizontal travel, it should go down 3.67 (of the same units). I recommend cutting a board that is 100 cm on one side and 3.67 cm on the other side. *It should be a triangle shape. *Then lay it on the tail in the correct location and use a bubble level on top of it to level the fuselage. The pointy end should be pointed toward the front of the glider. Another option (which is not as precise) use a long yardstick with a bubble level built-in. *Measure how long it is (let's assume it is 36" long) and use the ratio to calculate how high the back end should be lifted up off the tail. *36" x 3.67/100 = 1.3212". *You could tape something to the end of it to get it to sit on the tail at the correct height. Does that make sense? Good Soaring, Paul Remde "Artiom M" wrote in message .... Hi all, I’m trying to understand how to determine CofG of my DG-100. In the maintenance manual there is such sentence which I do not understand: “The fuselage must be leveled so that the top of the aft fuselage boom has a tail-down slope of l00 : 3.67.“ I understood that I need to lift up the sailplane tail, but what does 100:3.67 means? To what height? Can you help me with that? BR, Artiom. yes you are correct Don't forget to consider using the Program SeeG to help you with Weight and balance calculations (shameless plug). You can find out more at www.glideplan.com Cheers, Matt |
Same question, hopefully same answer...could use a little more info.
I'm trying to put together a W&B event at our club, we're bringing in outside help from another club with a set of scales and the experience of knowing what to do. WRT positioning the glider at the correct angle, my ship is an ASW-19b. Although my owners manual has a page dedicated to CG info, there's nothing in there about what procedure to use to actually weigh the thing. It's just a page with a CG envelope on it. Now I did find on page 30 of the manual (a page that has general dimensions as well as specs for control deflections) a side view drawing with info presented as the thread starter discussed, mine says 1000 by 45. SO, to do the procedure correctly, construct a small triangle with those dimensions, inflate the main wheel to proper pressure, put a level on the triangle, then raise the tail till I get a level bubble? It would seem to make sense that this is done with wings level laterally as well, correct? Lightly (fingertips) or is a wingstand under a tip ok? THEN, take the weights? Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly. Thanks much, Rob ASW-19b ZAP Last edited by RAS56 : January 11th 12 at 10:41 PM. |
Hey, Rob!
ZAP was my second glider. I flew her between April '88 and Nov '91. Blast from the past! "RAS56" wrote in message ... Same question, hopefully same answer...could use a little more info. I'm trying to put together a W&B event at our club, we're bringing in outside help from another club with a set of scales and the experience of knowing what to do. WRT positioning the glider at the correct angle, my ship is an ASW-19b. Although my owners manual has a page dedicated to CG info, there's nothing in there about what procedure to use to actually weigh the thing. It's just a page with a CG envelope on it. Now I did find on page 30 of the manual (a page that has general dimensions as well as specs for control deflections) a side view drawing with info presented as the thread starter discussed, mine says 1000 by 45. SO, to do the procedure correctly, construct a small triangle with those dimensions, inflate the main wheel to proper pressure, put a level on the triangle, then raise the tail till I get a level bubble? It would seem to make sense that this is done with wings level laterally as well, correct? Lightly (fingertips) or is a wingstand under a tip ok? THEN, take the weights? Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly. Thanks much, Rob ASW-19b ZAP -- RAS56 |
![]() Quote:
Great to hear a little history on her! I'm trying to treat her well and keep her flying down here in the Texas Hill Country outside of Austin. She went through a rough patch from '94 to '04...didn't fly and trailer leaks caused water damage on the fuse under the dolly which Gehrlein repaired...now only ~1040 TT. Would love to put 50-60 hours on it this season...put about 25 hours on in '11. Pass along any history to me at aggies78 at gmail dot com. Rob |
I've got a Glideplan file for the DG-100G that we have. I think I've
already got all the moments for ballast location and pilot established in that. Morgan On Jan 11, 10:24*am, "Matt Herron Jr." wrote: On Jan 11, 8:06*am, Tony wrote: On Jan 11, 9:10*am, Artiom M wrote: Many thanks for answers guys! Finally I understand how to do that. It seem to me the best idea is to cut a board and use a bubble level. Sounds great and easy to do! Thanks Paul! BR. Artiom. p.s. One more question... As English is not my native language can you describe in other words what “boom” means? As I understand this is a Pipe (part of fuselage from end of the wings to tail)? Am I right? ![]() On 11 Sau, 15:09, "Paul Remde" wrote: Hi Artiom, Good question. *It is a ratio. *For every 100 units (inches, mm, whatever) of horizontal travel, it should go down 3.67 (of the same units). I recommend cutting a board that is 100 cm on one side and 3.67 cm on the other side. *It should be a triangle shape. *Then lay it on the tail in the correct location and use a bubble level on top of it to level the fuselage. The pointy end should be pointed toward the front of the glider. Another option (which is not as precise) use a long yardstick with a bubble level built-in. *Measure how long it is (let's assume it is 36" long) and use the ratio to calculate how high the back end should be lifted up off the tail. *36" x 3.67/100 = 1.3212". *You could tape something to the end of it to get it to sit on the tail at the correct height. Does that make sense? Good Soaring, Paul Remde "Artiom M" wrote in message ... Hi all, I’m trying to understand how to determine CofG of my DG-100. In the maintenance manual there is such sentence which I do not understand: “The fuselage must be leveled so that the top of the aft fuselage boom has a tail-down slope of l00 : 3.67.“ I understood that I need to lift up the sailplane tail, but what does 100:3.67 means? To what height? Can you help me with that? BR, Artiom. yes you are correct Don't forget to consider using the Program SeeG to help you with Weight and balance calculations (shameless plug). * *You can find out more atwww.glideplan.com Cheers, Matt |
vibration measurement system | Stu Fields | Rotorcraft | 9 | May 27th 11 04:07 AM |
fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 04:34 AM |
TAS measurement | Bravo Delta | Piloting | 4 | June 30th 04 11:55 PM |
Time Measurement for Inspections | O. Sami Saydjari | Owning | 15 | April 7th 04 05:26 AM |
units of measurement on altimeters | Pat Norton | Piloting | 30 | March 21st 04 06:00 AM |
