Measurement of CofG
Old January 11th 12, 10:36 PM
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
Same question, hopefully same answer...could use a little more info.
I'm trying to put together a W&B event at our club, we're bringing in outside help from another club with a set of scales and the experience of knowing what to do.
WRT positioning the glider at the correct angle, my ship is an ASW-19b. Although my owners manual has a page dedicated to CG info, there's nothing in there about what procedure to use to actually weigh the thing. It's just a page with a CG envelope on it.
Now I did find on page 30 of the manual (a page that has general dimensions as well as specs for control deflections) a side view drawing with info presented as the thread starter discussed, mine says 1000 by 45.
SO, to do the procedure correctly, construct a small triangle with those dimensions, inflate the main wheel to proper pressure, put a level on the triangle, then raise the tail till I get a level bubble? It would seem to make sense that this is done with wings level laterally as well, correct? Lightly (fingertips) or is a wingstand under a tip ok? THEN, take the weights?
Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly.
Thanks much,
Rob
ASW-19b
ZAP
Old January 12th 12, 03:32 PM posted to rec.aviation.soaring
Dan Marotta
Default Measurement of CofG
Hey, Rob!
ZAP was my second glider. I flew her between April '88 and Nov '91.
Blast from the past!
"RAS56" wrote in message
45.
take the weights?
Thanks much,
Rob
ASW-19b
ZAP
RAS56
Old January 12th 12, 11:52 PM
Member
Quote:
Originally Posted by Dan Marotta View Post
Hey, Rob!
Dan,
Great to hear a little history on her!
I'm trying to treat her well and keep her flying down here in the Texas Hill Country outside of Austin.
She went through a rough patch from '94 to '04...didn't fly and trailer leaks caused water damage on the fuse under the dolly which Gehrlein repaired...now only ~1040 TT. Would love to put 50-60 hours on it this season...put about 25 hours on in '11.
Pass along any history to me at aggies78 at gmail dot com.
Rob
vibration measurement system Stu Fields Rotorcraft 9 May 27th 11 04:07 AM
fuel flow measurement khanindra jyoti deka Home Built 0 January 5th 05 04:34 AM
TAS measurement Bravo Delta Piloting 4 June 30th 04 11:55 PM
Time Measurement for Inspections O. Sami Saydjari Owning 15 April 7th 04 05:26 AM
units of measurement on altimeters Pat Norton Piloting 30 March 21st 04 06:00 AM
