![]() Quote:
Same question, hopefully same answer...could use a little more info. I'm trying to put together a W&B event at our club, we're bringing in outside help from another club with a set of scales and the experience of knowing what to do. WRT positioning the glider at the correct angle, my ship is an ASW-19b. Although my owners manual has a page dedicated to CG info, there's nothing in there about what procedure to use to actually weigh the thing. It's just a page with a CG envelope on it. Now I did find on page 30 of the manual (a page that has general dimensions as well as specs for control deflections) a side view drawing with info presented as the thread starter discussed, mine says 1000 by 45. SO, to do the procedure correctly, construct a small triangle with those dimensions, inflate the main wheel to proper pressure, put a level on the triangle, then raise the tail till I get a level bubble? It would seem to make sense that this is done with wings level laterally as well, correct? Lightly (fingertips) or is a wingstand under a tip ok? THEN, take the weights? Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly. Thanks much, Rob ASW-19b ZAP Ps-sorry if this double posts... |
I am sure I am not on my own when I say I have an Excel spreadsheet with
the calculations for C of G to be done. It may not be pretty but it does the job. If you want a copy email me. Croft At 04:51 12 January 2012, RAS56 wrote: Hagbard Celine;807559 Wrote: If the shop has a digital protractor you could also convert the rise/ run to degrees, put the protractor on the specified part of the tail boom and raise the tail until it reads the correct angle. Arctan(rise/run) = angle in degrees About 2.1 degrees, sloping down towards the tail in this case. Same question, hopefully same answer...could use a little more info. I'm trying to put together a W&B event at our club, we're bringing in outside help from another club with a set of scales and the experience of knowing what to do. WRT positioning the glider at the correct angle, my ship is an ASW-19b. Although my owners manual has a page dedicated to CG info, there's nothing in there about what procedure to use to actually weigh the thing. It's just a page with a CG envelope on it. Now I did find on page 30 of the manual (a page that has general dimensions as well as specs for control deflections) a side view drawing with info presented as the thread starter discussed, mine says 1000 by 45. SO, to do the procedure correctly, construct a small triangle with those dimensions, inflate the main wheel to proper pressure, put a level on the triangle, then raise the tail till I get a level bubble? It would seem to make sense that this is done with wings level laterally as well, correct? Lightly (fingertips) or is a wingstand under a tip ok? THEN, take the weights? Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly. Thanks much, Rob ASW-19b ZAP Ps-sorry if this double posts... -- RAS56 |
Croft,
If you could email it to me at: aggies78 at gmail.com That would be much appreciated! Thanks. Rob S. |
Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly. Thanks much, Rob ASW-19b Try http://www.gliding.co.uk/bgainfo/tec...manual/4-1.pdf which is a good guide to the process |
When we did my ASW-15 we took the weights just balancing the wings
level, no stand. Fore and aft level was done as you describe (my manual has about the same information as yours) with the exception I noted about using a digital protractor instead of making the triangle. As my ship was exported from Germany in 1998 we had copies of the W&B's they did there for my maintenance engineer to use as a guideline for making the new W&B and equipment list. The records that accompanied my ship when it was exported show that the W&B was done every second year when it was in Germany! I could get you scans of the forms though being of German origin they would be useful as a guideline at best. Sometimes you can get a surprise when doing a W&B. My club has a Grob 102 Standard III. When the A.D. requiring the installation of lead mass balance in the control system was done we naturally had to reweigh the glider. The last time it had been weighed was by a previous owner many years before we bought it. The new weight was about 80 pounds LESS than the last one. Aircraft generally don't LOSE weight over the years, especially when you've just bonded a bunch of lead to them. The maintenance shop double and triple checked their procedures, recalibrated their scales and reweighed the glider several times. The new weight was accurate. We're still trying to figure out what the hell was going on with the previous weighing. Water ballast left in the tanks maybe? On Jan 11, 8:51*pm, RAS56 wrote: Hagbard Celine;807559 Wrote: If the shop has a digital protractor you could also convert the rise/ run to degrees, put the protractor on the specified part of the tail boom and raise the tail until it reads the correct angle. Arctan(rise/run) = angle in degrees About 2.1 degrees, sloping down towards the tail in this case. Same question, hopefully same answer...could use a little more info. I'm trying to put together a W&B event at our club, we're bringing in outside help from another club with a set of scales and the experience of knowing what to do. WRT positioning the glider at the correct angle, my ship is an ASW-19b. Although my owners manual has a page dedicated to CG info, there's nothing in there about what procedure to use to actually weigh the thing. It's just a page with a CG envelope on it. Now I did find on page 30 of the manual (a page that has general dimensions as well as specs for control deflections) a side view drawing with info presented as the thread starter discussed, mine says 1000 by 45. SO, to do the procedure correctly, construct a small triangle with those dimensions, inflate the main wheel to proper pressure, put a level on the triangle, then raise the tail till I get a level bubble? It would seem to make sense that this is done with wings level laterally as well, correct? Lightly (fingertips) or is a wingstand under a tip ok? THEN, take the weights? Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly. Thanks much, Rob ASW-19b ZAP Ps-sorry if this double posts... -- RAS56 |
vibration measurement system | Stu Fields | Rotorcraft | 9 | May 27th 11 04:07 AM |
fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 04:34 AM |
TAS measurement | Bravo Delta | Piloting | 4 | June 30th 04 11:55 PM |
Time Measurement for Inspections | O. Sami Saydjari | Owning | 15 | April 7th 04 05:26 AM |
units of measurement on altimeters | Pat Norton | Piloting | 30 | March 21st 04 06:00 AM |
