Measurement of CofG
Old January 15th 12, 03:16 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Measurement of CofG
On Jan 11, 3:29*pm, "Dan Marotta" wrote:
Why don't the manufactures publish the height to raise the tail as a
difference between the axle center lines above ground? *Then you don't need
to cut or calculate.
Oh, gee... *That'd be too simple.
I specify W&B leveling with a level and wedge on the aft fuselage
because it is the simplest and easiest way of getting the glider
level. You make the wedge and keep it in the glider's toolbox, or you
use a digital level as somebody else suggest. I don't see what's so
hard or complicated about that.
I have actually designed in a couple of internal surfaces that are
parallel with the glider's x axis, but they are in under the wing spar
and you can't see them while actually doing the leveling. With the
level on the aft fuselage, you can actually see it while you are
raising and lowering the tail to find the level.
To specify the level in terms of height of the axles, you have to know
the distances of the axles from the x axis, which is not simple
because the gear might have an oleo strut (as does mine), and you
don't know if the tailwheel location has been changed or modified.
Also, when leveling to the axles, you have to know what you're
leveling to. If you have a hangar or shop floor known to be level,
you're golden. But if you're doing a W&B in the field or on grass or
another uneven surface, then you need to construct a water level or
other surveying tool. By then, the bubble level on the aft fuselage
starts to look pretty good.
Thanks, Bob K.
Old January 15th 12, 04:57 PM posted to rec.aviation.soaring
Dan Marotta
Thanks for a good technical reply.
Now I just have to check and see if any of my measuring devices have decimal
inch/cm graduations. Seems most are graduated in 1/16th, etc... Let/s
see... That would be 200 inches long and 2 and 14.4/16 inches high. Oh,
crap! There's that pesky decimal again. I know - I'll make my triangle
2,000 inches long and 29 inches high! Now, if I could just find a surface
on the glider where I can make that fit.
Really, how accurately can you measure 2.9 inches, mark it, and cut it? I
don't have a machine shop. This all reminds me of the old Air Force adage:
"Measure with a micrometer, mark with a grease pencil, cut with an axe".
I've been out of school for a long time, so my calculation is probably
wrong, but it looks like 100:2.9 is an angle of 1.6618 degrees. Will a
digital level get that accuracy? Is that accuracy really necessary?
What's the good of a parallel surface if it's not accessible? Why not make,
say, the arm rest parallel to the longitudinal axis? Then you could simply
place a carpenter's level on the arm rest and, voila!
And, BTW, you shouldn't really be doing a weight and balance in a grassy
field, no matter how level it is. The slightest breeze will generate some
measureable amount of lift and throw your weight measurement off. And if
that weight change is not enough to be concerned with, then I challenge the
need to measure the angle of the fuselage to the thousandth of a degree
(measure with a micrometer).
Bottom line - that's what the manufacturer says to do and I'll try my best
to do it that way, but I'm not going to lose any sleep over it.
"Bob Kuykendall" wrote in message
difference between the axle center lines above ground? Then you don't need
Oh, gee... That'd be too simple.
Thanks, Bob K.
Old January 16th 12, 12:10 AM posted to rec.aviation.soaring
Bob Kuykendall
I think that just on the far side of 2-7/8" would do just fine.
...it looks like 100:2.9 is an angle of 1.6618 degrees. *Will a
Most digital levels will offer repeatable measurements to 0.1 degrees,
and I think that that is close enough. In this case I'd feel fine
about a reading of 1.7 degrees. For my fuselage, the exact tailboom
slope is 1.213 degrees, but 1.2 or even 1-1/4 degrees would be fine.
What's the good of a parallel surface if it's not accessible? *Why not make,
say, the arm rest parallel to the longitudinal axis? *Then you could simply
Thanks, the armrest trick is a good idea, I might adopt that; it would
be useful for people who have digital levels that beep when they're
actually level.
Thanks again, Bob K.
Old January 16th 12, 04:13 PM posted to rec.aviation.soaring
Dan Marotta
I like the idea of a "beeping" level which would allow a single person to
complete the operation. And I *really* like the design of Wayne's "wedge".
Bob, thanks for stating what I've always felt, i.e., the TLAR method is good
enough (2-7/8"). I was (wrongly) getting the impression that people were
stuck on precision which I couldn't attain. It would seem pointless to
measure the angle to a gnat's ass and then fly with boots and a heavy jacket
one day and shorts and sneakers the next.
One more time - Wayne, I LIKE the design of your wedge. I think I'll build
one. And ask the manufacturer why they don't include at least a drawing for
a device to level the fuselage.
...it looks like 100:2.9 is an angle of 1.6618 degrees. Will a
make,
actually level.
Old January 16th 12, 11:23 PM posted to rec.aviation.soaring
Brad[_2_]
complete the operation. *And I *really* like the design of Wayne's "wedge".
enough (2-7/8"). *I was (wrongly) getting the impression that people were
stuck on precision which I couldn't attain. *It would seem pointless to
One more time - Wayne, I LIKE the design of your wedge. *I think I'll build
one. *And ask the manufacturer why they don't include at least a drawing for
digital level get that accuracy? *Is that accuracy really necessary?
make,
actually level.
when we did the W & B for my Tetra we used a 24" level and a 1/2" tall
socket, with the level located as required by Bob it was easy to set
everything up on scales. I had my engineer friend do the
math............empty weight came out at 479 pounds!
Brad
Old January 16th 12, 09:53 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
decimal
adage:
Why would you want to use inches specifically? the ratio 2000:29 could be
inches, millimeters, bananas or ay other unit you might wish to use, that
is why it is expressed that way, works whatever system of measurement you
care to use. A distance of 10000mm with a drop of 145mm would seem to me
pretty easy to set up.
Old January 16th 12, 10:31 PM posted to rec.aviation.soaring
Dan Marotta
Actually, I mistyped. It's 100:2.9 and, yes, I understand that it's a ratio
and unitless. Still, I don't have any tools which measure nine tenths of
anything, be they banannas, apples, inches, or millimeters. The point I was
trying to make is that such precision as 1/1000th of a degree really isn't
necessary. When I attended engineering school, I used a slide rule, not a
computer, and I learned that close enough is good enough.
"Don Johnstone" wrote in message
.com...
decimal
adage:
Old January 15th 12, 05:27 PM posted to rec.aviation.soaring
As Bob mentioned, building a wedge for your gilder is a good solution the
will provide accurate results time after time. Here is the wedge that I use
for my HP-14. I'm sure the dimensions required to build a similar device
are available for production aircraft.
http://www.soaridaho.com/Schreder/Co...uselage_Level/
HP-14 "6F"
need
Thanks, Bob K.
vibration measurement system Stu Fields Rotorcraft 9 May 27th 11 04:07 AM
fuel flow measurement khanindra jyoti deka Home Built 0 January 5th 05 04:34 AM
TAS measurement Bravo Delta Piloting 4 June 30th 04 11:55 PM
Time Measurement for Inspections O. Sami Saydjari Owning 15 April 7th 04 05:26 AM
units of measurement on altimeters Pat Norton Piloting 30 March 21st 04 06:00 AM
