Actually, I mistyped. It's 100:2.9 and, yes, I understand that it's a ratio
and unitless. Still, I don't have any tools which measure nine tenths of anything, be they banannas, apples, inches, or millimeters. The point I was trying to make is that such precision as 1/1000th of a degree really isn't necessary. When I attended engineering school, I used a slide rule, not a computer, and I learned that close enough is good enough. "Don Johnstone" wrote in message .com... At 16:57 15 January 2012, Dan Marotta wrote: Thanks for a good technical reply. Now I just have to check and see if any of my measuring devices have decimal inch/cm graduations. Seems most are graduated in 1/16th, etc... Let/s see... That would be 200 inches long and 2 and 14.4/16 inches high. Oh, crap! There's that pesky decimal again. I know - I'll make my triangle 2,000 inches long and 29 inches high! Now, if I could just find a surface on the glider where I can make that fit. Really, how accurately can you measure 2.9 inches, mark it, and cut it? I don't have a machine shop. This all reminds me of the old Air Force adage: Why would you want to use inches specifically? the ratio 2000:29 could be inches, millimeters, bananas or ay other unit you might wish to use, that is why it is expressed that way, works whatever system of measurement you care to use. A distance of 10000mm with a drop of 145mm would seem to me pretty easy to set up. |
vibration measurement system | Stu Fields | Rotorcraft | 9 | May 27th 11 04:07 AM |
fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 04:34 AM |
TAS measurement | Bravo Delta | Piloting | 4 | June 30th 04 11:55 PM |
Time Measurement for Inspections | O. Sami Saydjari | Owning | 15 | April 7th 04 05:26 AM |
units of measurement on altimeters | Pat Norton | Piloting | 30 | March 21st 04 06:00 AM |
