Position Recorders, Accuracy, and Badge altitude gains
Old May 28th 12, 11:41 PM posted to rec.aviation.soaring
Darryl Ramm
Default Position Recorders, Accuracy, and Badge altitude gains
On Monday, May 28, 2012 12:13:57 PM UTC-7, Marc wrote:
On May 28, 11:59*am, uros wrote:
I have checked both flights and for the first flight it seems to me
that the flight recorder was turned on too late. Every GPS needs some
time to find correct position and when the GPS is moving this time is
even longer. The correct procedure is to turn on the GPS few minutes
before the flight so that GPS could correctly find first position and
will start recording correctly. These jumps could be easily detected
and the recording would be cut off.
Uros, if the GPS was engaged in cold/warm start and recording 2D or
degraded fixes, why wasn't the navigation warning flag set (V in
column 24 of the B records)?
Marc
And if the fixes were 2D why was the GPS altitude not recorded as zero. At least that's is a requirement of IGC flight recorders--I'll admit to being lost as to what actual hard specs the NACs are supposed to hold position recorder manufacturers too. I hope the SSA is looking at this.
Darryl
Position recorders for badges fredblair Soaring 5 March 1st 12 07:01 PM
Position Recorders allowed the US for Silver badges? Bastoune Soaring 15 September 22nd 11 01:45 AM
Any Badge Claims Using GPS Position Recorder plus Barograph? Papa3 Soaring 6 September 15th 10 10:19 PM
WAAS question -- altitude accuracy? Craig Davidson Piloting 10 September 23rd 03 09:56 PM
gps altitude accuracy Martin Gregorie Soaring 12 July 18th 03 08:51 PM
