Becker AR3201
Old March 25th 13, 09:48 AM posted to rec.aviation.soaring
David Salmon[_2_]
Default Becker AR3201
At 10:54 24 March 2013, Lazarost wrote:
Hi to all.
I'm electronic technician and i start to repair some equipments for
gliders and planes.So i have a problem with a Becker AR3201. The problem
is when you press the PTT to talk or you receive a signal you hear at
the headset or at the speakers a noise like the noise from alternator. I
try to install a power line filter but without any success. I try with
the engine not running (only with the battery) and the problem is still
presents.
Any idea what happen ???
Thanks for any help.
Lazaros Greece
Lazarost
I know next to nothing about radios, but could it be that the squelch needs
turning down? On the 3201 there is an adjustment screw that you get at
through the lowest of 3 holes in the RH side of the casing.
Dave
Becker AR3201 [email protected] Soaring 4 April 6th 09 11:15 PM
AR3201 Harness? noel.wade Soaring 13 March 10th 09 02:23 PM
Wanted: Becker AR3201 Ira Blieden Soaring 0 December 14th 06 06:28 PM
Looking for a Becker AR3201 Ira Blieden Soaring 0 December 8th 06 01:38 PM
Problems with Becker [email protected] Soaring 6 August 26th 05 09:33 AM
