Strobl-Solar: questions about panels, wiring, and switching
Old March 19th 14, 09:43 PM posted to rec.aviation.soaring
Jim White[_3_]
Default Strobl-Solar: questions about panels, wiring, and switching
At 16:35 19 March 2014, JS wrote:
I have had Strobl 2-panel units on a couple of gliders.
Even using SLA batteries, with the glider tied down outside overnight
between flights I could keep the batteries charged on a panel which had
no
VGA display.
Using LiFePO4 batteries the 2-panel system will keep the batteries
charged.
That panel was perhaps "full monty", having com, txp, vario, VGA, flarm.
Interestingly, leaving the ClearNav on and removing the batteries, in
full sun the 2-panel Strobl rig would keep the CN running if on minimum
brightness.
That glider had the Strobl charger on the avionics bus, so whatever
battery was selected was being charged.
Strobl also sells a dual battery charger.
Mine is two panel providing over 750ma in full sunlight. It connects
directly to both batteries using a two channel controller. I don't have a
switch, it seems to work it out for itself. Just works. Simples. Thorughly
recommend it.
Batteries (again) - 2 Main Batts plus Tail Fin Batt wiring/switching Neil Allison Soaring 4 November 20th 07 06:42 AM
Batteries, Solar Panels, Transponders, etc. JS Soaring 7 August 31st 06 09:12 PM
Pneumatic switching? bumper Soaring 5 March 15th 05 02:58 AM
Switching instructors? Dave Jacobowitz Piloting 13 November 5th 04 09:32 PM
Thin flexible solar panels Eric Greenwell Soaring 11 November 28th 03 04:35 PM
