Sustainer/turbo gliders
Old April 5th 15, 11:03 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Sustainer/turbo gliders
Somehow this turned into a FES thread, not what I had intended. I would like comments from those with curent generation pop up factory installed sustainers. I noticed the POH's do not have performance information other than Standard conditions. Say if you have a solo 2350 what is the ceiling of climb ability? What are actual achieved results? Do you find you get less soaring as you have to stop looking for lift at a much higher altitude, and yo have a high minimum wing loading. Are you happy with the sustainer or do you wish you had gotten a pure glider? What are the downsides, the upsides. Have you experienced a failure to extend or to start, any idea what is the glider ration with engine extended. Do you prefer the two blades of Schleicher designs or the five blades of Schempp-Hirth, anyone flow a JS with jet? Does the sustainer make your flights safer as the possibility of a land is reduced. Has anyone suffered a failure resulting in damage? I am looking for as much information as the readers are willing to share. As for FES, we can start another thread but for this discussion I am interested in factory installed sustainers. Thank you all very much for your time and input.
Old April 5th 15, 11:58 PM posted to rec.aviation.soaring
Jonathan,
Understand, but for the record, the FES was a "factory installed sustainer." With that you will hear not a word more from me on this subject....
Good luck in your research and have a safe soaring season.
Thx - Renny
Old April 6th 15, 12:55 AM posted to rec.aviation.soaring
jfitch
I do not own a sustainer, rather a motorglider (ASH26e) but some of the experience is relevant. 1) If you are looking at any auxiliary engine as a safety device, I think you will eventually be disappointed if not injured. 2) An engine significantly increases the pilot workload at just the moment you would like it to be reduced, that is when low and looking for lift or a landing site. 3) An engine increases maintenance for a glider by around 2x or maybe more. These are realities that must be considered along with any perceived benefits.
Old April 6th 15, 01:10 AM posted to rec.aviation.soaring
Dave Nadler
2x? Dream on!!!
Old April 6th 15, 01:38 AM posted to rec.aviation.soaring
5U
I owned a V2CXT for 4 years. Started the engine every flight. It never failed. Not one time. I never touched the solo
engine. Never even changed the spark plugs. An excellent machine. 5U
Old April 6th 15, 01:59 AM posted to rec.aviation.soaring
Jonathan St. Cloud
5U, did you ever use the engine for a low save, is there such a thing or is it always a save from 2,000 agl? How long do you run the engine on each flight, what type of climb rate did you achieve to what density altitude? thank you
Old April 8th 15, 06:55 PM posted to rec.aviation.soaring
David Salmon[_3_]
li=
sust=
than=
cl=
s=
and
d=
upsid=
is=
of
wi=
a=
am=
f=
interested=
an=
d input.
A couple of further points. I don't think I have ever climbed above about
4500 amsl,and never noticed any fall off in climb. Our engine was retro
fitted to a glider already made to take an engine, but not fitted when new.
The engine takes 25 seconds to erect, so away from home I use 1500 above
ground as the height to get the engine out, but quite happily start it from
a 1000 winch launch. My partner in another glider has a Ventus 2t which
only takes 15 seconds to erect, but occasionally pops the circuit breaker.
I suspect on later engines they reduced the gearing to reduce amps, our
circuit breaker has never popped.
We always ensure that the carbs are filled before flying, but our engine
rarely starts cleanly, it seems to fire on one cylinder for 5/10 secs
before developing full power.
Dave
Boost performance of Solo 2350 turbo (sustainer) [email protected] Soaring 10 January 4th 19 12:37 PM
ASG-29E vs. JS-1Jet Sustainer Gerry Simpson Soaring 52 July 8th 15 01:29 PM
Turbo performance vs non-turbo John Doe Owning 22 October 8th 05 02:34 AM
sustaining (turbo) gliders Pilot626 Soaring 4 March 1st 05 03:30 AM
Converting engine from Turbo to non-Turbo Dick Kurtz Home Built 7 October 31st 03 04:48 PM
