Sustainer/turbo gliders
Old April 5th 15, 11:58 PM posted to rec.aviation.soaring
Default Sustainer/turbo gliders
On Sunday, April 5, 2015 at 4:03:05 PM UTC-6, Jonathan St. Cloud wrote:
Somehow this turned into a FES thread, not what I had intended. I would like comments from those with curent generation pop up factory installed sustainers. I noticed the POH's do not have performance information other than Standard conditions. Say if you have a solo 2350 what is the ceiling of climb ability? What are actual achieved results? Do you find you get less soaring as you have to stop looking for lift at a much higher altitude, and yo have a high minimum wing loading. Are you happy with the sustainer or do you wish you had gotten a pure glider? What are the downsides, the upsides. Have you experienced a failure to extend or to start, any idea what is the glider ration with engine extended. Do you prefer the two blades of Schleicher designs or the five blades of Schempp-Hirth, anyone flow a JS with jet? Does the sustainer make your flights safer as the possibility of a land is reduced. Has anyone suffered a failure resulting in damage? I am looking for as much information as the readers are willing to share. As for FES, we can start another thread but for this discussion I am interested in factory installed sustainers. Thank you all very much for your time and input.
Jonathan,
Understand, but for the record, the FES was a "factory installed sustainer." With that you will hear not a word more from me on this subject....
Good luck in your research and have a safe soaring season.
Thx - Renny
Boost performance of Solo 2350 turbo (sustainer) [email protected] Soaring 10 January 4th 19 12:37 PM
ASG-29E vs. JS-1Jet Sustainer Gerry Simpson Soaring 52 July 8th 15 01:29 PM
Turbo performance vs non-turbo John Doe Owning 22 October 8th 05 02:34 AM
sustaining (turbo) gliders Pilot626 Soaring 4 March 1st 05 03:30 AM
Converting engine from Turbo to non-Turbo Dick Kurtz Home Built 7 October 31st 03 04:48 PM
