http://www.tauntontrailers.co.uk/kno...amper-12-p.asp
Seems to match your part number, from Tom Dukerich's excellent post below. Thanks to you both for bringing it up and sourcing the part! ( I have similar problems with a vintage Komet and was considering drastic americanization. Maybe there's an easier way. ) On Monday, May 18, 2015 at 3:38:54 PM UTC-5, wrote: Hoping someone on this group has sourced a surge damper for a Komet Trailer built in 1986. I have already taken the trailer tongue apart and the damper is a "Stabilus" brand (made in Germany) I believe the part number is "87 0007 09/S". Also on the damper is are the following line of numbers "067997 01 22 126 12/86 D79". I believe the part number is the first number listed. I am trying to source this part either in the USA or delivered to USA. I have sent an email to Knott-Bremsentechnik in Germany the supplier of the Trailer tongue and brakes for Komet but have not heard back (hope someone there reads English). There is also a Stabilus USA location in the North Carolina that I am attempting to contact. I believe the damper to be a combination of gas spring and dampener however I can't readily discern from any of the numbers on the unit what spring rate or dampening rate so it would be hard to spec a different manufacturer.. I am willing to use an alternate unit if I only have to make a bushing or new threaded end fitting. Thanks Mel N68LS LS6-A |
When I ordered my damper I also bought the bellows -
http://www.tauntontrailers.co.uk/kno...llows-81-p.asp and break-away cable - http://www.tauntontrailers.co.uk/bre...ables-38-c.asp On Wednesday, May 20, 2015 at 6:52:41 AM UTC-7, Sarah wrote: http://www.tauntontrailers.co.uk/kno...amper-12-p.asp Seems to match your part number, from Tom Dukerich's excellent post below.. Thanks to you both for bringing it up and sourcing the part! ( I have similar problems with a vintage Komet and was considering drastic americanization. Maybe there's an easier way. ) On Monday, May 18, 2015 at 3:38:54 PM UTC-5, wrote: Hoping someone on this group has sourced a surge damper for a Komet Trailer built in 1986. I have already taken the trailer tongue apart and the damper is a "Stabilus" brand (made in Germany) I believe the part number is "87 0007 09/S". Also on the damper is are the following line of numbers "067997 01 22 126 12/86 D79". I believe the part number is the first number listed. I am trying to source this part either in the USA or delivered to USA.. I have sent an email to Knott-Bremsentechnik in Germany the supplier of the Trailer tongue and brakes for Komet but have not heard back (hope someone there reads English). There is also a Stabilus USA location in the North Carolina that I am attempting to contact. I believe the damper to be a combination of gas spring and dampener however I can't readily discern from any of the numbers on the unit what spring rate or dampening rate so it would be hard to spec a different manufacturer. I am willing to use an alternate unit if I only have to make a bushing or new threaded end fitting. Thanks Mel N68LS LS6-A |
Komet surge brake | Tony V | Soaring | 7 | October 25th 12 03:24 AM |
Komet trailer damper replacement | Wheaton | Soaring | 3 | June 28th 12 02:29 AM |
Trailer Tongue Gas Strut replacement | Colin Mead | Soaring | 2 | May 18th 12 03:17 PM |
Komet trailer tongue | key[_2_] | Soaring | 6 | February 5th 11 01:19 AM |
Trailer tongue failure | [email protected] | Soaring | 8 | March 17th 08 03:45 AM |
