At 01:48 19 May 2015, bumper wrote:
On Monday, May 18, 2015 at 2:38:43 PM UTC-7, PBA wrote: Back on topic...is there good material to protect the underbelly of a sa= ilplane?=20 I would be interested in protecting the base of the wing spar opening on = the fuselage. Years of assemblies have started to wear a groove and it's ge= tting thin. Something Teflon Based? I see from a previous post, not an easy= material to bond to something else. The material for that is UHMW PE tape, available in various thicknesses and= widths, with either rubber or acrylic adhesive. Common thickness ranges fr= om about .005" to .020". Available from McMaster-Carr or Amazon etc.=20 Note that as you approach 10 mills, the tape starts getting more rigid and = is suitable mostly for flatter surfaces. For lining the fuselage spar openi= ngs, you'll want .005" (or there'bouts, and acrylic adhesive). UHMW PE is almost as slick as Teflon, but has much higher mechanical streng= th. Teflon, will slippery, is not nearly as wear resistant or useful as an = anti-abrasion liner. For tough jobs, UHMW is best.=20 bumper I probably have a dozen rolls of UHMW PE in various calibers in my hangar := d) My friend and I had this problem on our gliders, a DG200 and Std Cirrus respectively. Measure the depth of the groove. Lay up several sheets/strip of glass fibre on a layer of plastic sheet on a workbench. When cured cut to length, check the strip fits the groove and brings the level of the unworn part of the fuselage. Attach in place with resin. When the resin has cured file/sand to a smooth finish, less than 10 minutes work each side. Result is a durable smooth surface for the spar to slide into the fuselage at the right height bringing joy back to rigging again. An inspector checked our handy work and was most impressed. I may have to repeat again in another 1500 assemblies/43 years! Gavin Std Cirrus, G-SCNN, #173 SFV Südeifel, Utscheid, Germany |
Remove layer of cloth/Gelcoat | glider[_2_] | Soaring | 1 | February 9th 10 07:39 PM |
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (0/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 07:31 PM |
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 07:31 PM |
composite using aluminum windowscreen layer | Allan Morrison | Home Built | 4 | January 27th 05 01:19 PM |
sacrificial aluminum | Rob | Home Built | 1 | July 12th 04 09:45 PM |
