Wanted: Cambridge Mark IV Vario and Flight Director with Audio
Old May 19th 16, 10:52 PM posted to rec.aviation.soaring
Default Wanted: Cambridge Mark IV Vario and Flight Director with Audio
Looking for an old, working, Mark IV with internal TE compensation for a motor glider that does not have a TE probe line installed. Dave Milner at milnerdv at yahoo.com
Old May 19th 16, 11:03 PM posted to rec.aviation.soaring
Ben Coleman
There's a MkIV he
http://glidersales.com.au/instruments.php
I don't know about the compensation though (just saw it when browsing there).
Cheers Ben
Old May 20th 16, 02:03 AM posted to rec.aviation.soaring
Greg Delp
I've got both that I pulled out of a Grob 104 when I installed a newer Digital smart vario. If you're interested send me a message and I can send pics.
Old May 20th 16, 12:41 PM posted to rec.aviation.soaring
On Thursday, May 19, 2016 at 6:03:58 PM UTC-4, Ben Coleman wrote:
There's a MkIV he
Cheers Ben
I contacted the seller and it was sold a long time ago. It seems like no modern vario's have internal TE compensation because every new glider in the past 20 years or more is built with the plumbing for a TE probe at the factory. Some higher end vario's from the 70's had electronic TE compensation built into them. My guess is because they were being retrofitted into gliders that did not have the plumbing already. The other option is to find a Schuemann "Magic Box" pneumatic compensator.
I have a Westerboer VW910 and VW921 currently but it doesn't really work for the Vivat as you have to select from a few pre-programmed glide polars and they are all much higher performance than the Vivat.
Dave
Old May 20th 16, 02:12 PM posted to rec.aviation.soaring
Ben Coleman
I think most of the new electronic varios have non-TE compensation options. Definately LX and Clearnav. Or are you after a backup?
Cheers Ben
Old May 20th 16, 08:15 PM posted to rec.aviation.soaring
Tim Taylor
302 also has a non-TE configuration. It works nearly as well as the TE option.
CAV 11 Audio Vario/no Audio ideas? (Cambridge) Gregg Leslie[_2_] Soaring 3 June 4th 11 12:08 AM
Cambridge Audio/Variometer/Speed Director For Sale - Make Offer Scott Alexander[_2_] Soaring 0 November 30th 10 06:02 PM
Schematics for Cambridge CVS50 vario and audio unit? Or anyoneselling a similar working audio variometer? Bret Soaring 0 August 30th 10 04:24 AM
Cambridge L-Nav audio vario just ate it... Bruno Soaring 9 November 18th 09 10:49 PM
FS: Cambridge CAV-II vario/audio/averager [email protected] Soaring 1 May 13th 09 01:41 AM
