Al-Ko Trailer Tongue failure
Old July 10th 16, 05:32 PM posted to rec.aviation.soaring
Default Al-Ko Trailer Tongue failure
On Sunday, July 10, 2016 at 12:19:29 PM UTC-4, wrote:
If you have frequent issues with dragging, consider shimming your trailer axle with a 1" or 2" tube.
A size large (diameter) tires does the same. 1/2" at the axle gives about twice that much more clearance at the aft end of the trailer.
Of course, if you rig while the trailer is hitched to the tow vehicle, that changes the angle of departure when you're pulling the fuselage out (watch out for scrapes) and forces you to lift the spars off the dollies from a higher position. Nothing is free in this world.
Chip Bearden
ASW 24 "JB"
Komet Trailer tongue surge damper needed [email protected] Soaring 3 May 21st 15 05:02 AM
Trailer Tongue Gas Strut replacement Colin Mead Soaring 2 May 18th 12 03:17 PM
Komet trailer tongue key[_2_] Soaring 6 February 5th 11 01:19 AM
Trailer tongue failure [email protected] Soaring 8 March 17th 08 03:45 AM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
