Komet Trailer tongue surge damper needed
Old May 18th 15, 09:38 PM posted to rec.aviation.soaring
Default Komet Trailer tongue surge damper needed
Hoping someone on this group has sourced a surge damper for a Komet Trailer built in 1986. I have already taken the trailer tongue apart and the damper is a "Stabilus" brand (made in Germany) I believe the part number is "87 0007 09/S". Also on the damper is are the following line of numbers "067997 01 22 126 12/86 D79". I believe the part number is the first number listed.. I am trying to source this part either in the USA or delivered to USA.
I have sent an email to Knott-Bremsentechnik in Germany the supplier of the Trailer tongue and brakes for Komet but have not heard back (hope someone there reads English). There is also a Stabilus USA location in the North Carolina that I am attempting to contact.
I believe the damper to be a combination of gas spring and dampener however I can't readily discern from any of the numbers on the unit what spring rate or dampening rate so it would be hard to spec a different manufacturer. I am willing to use an alternate unit if I only have to make a bushing or new threaded end fitting.
Thanks
Mel
N68LS
LS6-A
Old May 20th 15, 05:47 AM posted to rec.aviation.soaring
Tom Dukerich[_2_]
http://www.tauntontrailers.co.uk
I know it is a UK website, but my order was delivered to Phoenix in a short amount on time.
Tom
On Monday, May 18, 2015 at 1:38:54 PM UTC-7, wrote:
Hoping someone on this group has sourced a surge damper for a Komet Trailer built in 1986. I have already taken the trailer tongue apart and the damper is a "Stabilus" brand (made in Germany) I believe the part number is "87 0007 09/S". Also on the damper is are the following line of numbers "067997 01 22 126 12/86 D79". I believe the part number is the first number listed. I am trying to source this part either in the USA or delivered to USA.
I believe the damper to be a combination of gas spring and dampener however I can't readily discern from any of the numbers on the unit what spring rate or dampening rate so it would be hard to spec a different manufacturer.. I am willing to use an alternate unit if I only have to make a bushing or new threaded end fitting.
Thanks
Mel
N68LS
LS6-A
Old May 20th 15, 02:52 PM posted to rec.aviation.soaring
Sarah[_2_]
http://www.tauntontrailers.co.uk/kno...amper-12-p.asp
Seems to match your part number, from Tom Dukerich's excellent post below.
Thanks to you both for bringing it up and sourcing the part!
( I have similar problems with a vintage Komet and was considering drastic americanization. Maybe there's an easier way. )
Thanks
Mel
N68LS
LS6-A
Old May 21st 15, 05:02 AM posted to rec.aviation.soaring
Tom Dukerich[_2_]
When I ordered my damper I also bought the bellows -
http://www.tauntontrailers.co.uk/kno...llows-81-p.asp
and break-away cable -
http://www.tauntontrailers.co.uk/bre...ables-38-c.asp
Seems to match your part number, from Tom Dukerich's excellent post below..
Hoping someone on this group has sourced a surge damper for a Komet Trailer built in 1986. I have already taken the trailer tongue apart and the damper is a "Stabilus" brand (made in Germany) I believe the part number is "87 0007 09/S". Also on the damper is are the following line of numbers "067997 01 22 126 12/86 D79". I believe the part number is the first number listed. I am trying to source this part either in the USA or delivered to USA..
Thanks
Mel
N68LS
LS6-A
Komet surge brake Tony V Soaring 7 October 25th 12 03:24 AM
Komet trailer damper replacement Wheaton Soaring 3 June 28th 12 02:29 AM
Trailer Tongue Gas Strut replacement Colin Mead Soaring 2 May 18th 12 03:17 PM
Komet trailer tongue key[_2_] Soaring 6 February 5th 11 01:19 AM
Trailer tongue failure [email protected] Soaring 8 March 17th 08 03:45 AM
