On Saturday, February 3, 2018 at 8:21:17 PM UTC-8, Charles Longley wrote:
The head diameter on that screw is too big. I need a 4 mm screw with a head diameter around 6.5 mm. I am not sure what the countersink angle is. Looks closer to 100 though. That head diameter is totally unrealistic; it should be about twice the shaft diameter. Grind the head down if you want it less, but you will have a very small shoulder as a result. Tom |
Fairey Long-range Monoplane pics 2 [4/9] - Like the first machine, it is fitted with a Napier Lion engine. Refinements have been added to this second machine, such as the spats over the undercarriage wheels.jpg (1/1) | Miloch | Aviation Photos | 0 | January 6th 18 04:31 PM |
Blanik screws? | Wade G | Soaring | 10 | March 28th 16 03:03 AM |
Metric Aircraft Hardware | [email protected] | Soaring | 2 | November 27th 07 06:23 AM |
FAA Screws Up Again | BushOKDemocratsSTUPID | Instrument Flight Rules | 2 | March 22nd 06 10:39 PM |
Metric Aircraft Nuts and Bolts | John Scott | Soaring | 6 | December 14th 05 08:54 PM |
