You won't believe this but as good a solution is on eBay for $15.00. Search for EBC 303 Brake shoes. You may need to machine a little to fit drum, but lining material is softer than the $90 Toast replacement. Thus, they don't glaze up as quick. Uncanny in that the cast, springs and other that the brake material are identical.
Still not a perfect solution, but if you are gentle on the brakes you can go a full season. Enjoy and buy a beer with what you save. Joe |
On Tuesday, May 21, 2019 at 8:28:19 AM UTC-4, Hartley Falbaum wrote:
I am trying to improve the brakes on a Libelle 201B. I replaced the shoes and de-glazed the drum recently but not much help. I trued the drum on a mandrel in a 10" Clausing lathe. I mounted the backing plate and shoes on another mandrel, intending to true the shoes, but got readings that told me the shoes would have to be expanded. I had no good way to do that without getting excessive clearance. So I just deglazed them. After installation, I had to max-out the one adjuster in order to get the proper tension on the handbrake. I noticed a threaded hole in the brake handle, centered on the cable. Looks like a setscrew belongs there for adjusting cable length. So--here's my question-----What style of setscrew point belongs there? Flat tip, or dog point (extended tip). I presume a cup point would damage the cable. Thanks in advance for any factual knowledge. Hartley Falbaum hfalbaum at comcast dot com Mine (SN 470) has a hex-head bolt with a slot for a screwdriver. The end of the shank is flat. |
So if there is not setscrew in your brake handle, how is the brake cable attached? Does it go all the way through the handle and then have a soldered in stop sticking out from the back side? I've seen at least one other Libelle that was cobbled together incorrectly like that so just wondering.
Robert On Tuesday, May 21, 2019 at 7:28:19 AM UTC-5, Hartley Falbaum wrote: I am trying to improve the brakes on a Libelle 201B. I replaced the shoes and de-glazed the drum recently but not much help. I trued the drum on a mandrel in a 10" Clausing lathe. I mounted the backing plate and shoes on another mandrel, intending to true the shoes, but got readings that told me the shoes would have to be expanded. I had no good way to do that without getting excessive clearance. So I just deglazed them. After installation, I had to max-out the one adjuster in order to get the proper tension on the handbrake. I noticed a threaded hole in the brake handle, centered on the cable. Looks like a setscrew belongs there for adjusting cable length. So--here's my question-----What style of setscrew point belongs there? Flat tip, or dog point (extended tip). I presume a cup point would damage the cable. Thanks in advance for any factual knowledge. Hartley Falbaum hfalbaum at comcast dot com |
I am trying to improve the brakes on a Libelle 201B. I replaced the shoes and de-glazed the drum recently but not much help. I trued the drum on a mandrel in a 10" Clausing lathe. I mounted the backing plate and shoes on another mandrel, intending to true the shoes, but got readings that told me the shoes would have to be expanded. I had no good way to do that without getting excessive clearance. So I just deglazed them. After installation, I had to max-out the one adjuster in order to get the proper tension on the handbrake. I noticed a threaded hole in the brake handle, centered on the cable. Looks like a setscrew belongs there for adjusting cable length. So--here's my question-----What style of setscrew point belongs there? Flat tip, or dog point (extended tip). I presume a cup point would damage the cable. Thanks in advance for any factual knowledge. Hartley Falbaum hfalbaum at comcast dot com Right--there is no setscrew. The cable has a swedged on copper end sleeve. It is not my glider. I'm thinking it does need the setscrew. I like the aluminum slug idea. Hartley |
Looking for Tost Standard Drum Brake Wheel (USA) | [email protected] | Soaring | 2 | March 28th 19 12:11 PM |
Modifying Std Libelle with Tost Lilliput Wheel | [email protected] | Soaring | 10 | September 19th 17 06:51 PM |
Tost Disk Brake rebuild? | Paul Cordell | Soaring | 10 | April 17th 08 07:20 AM |
Tost brake bolt shears off - the answer | Jack Glendening | Soaring | 1 | September 30th 07 01:16 PM |
Tost brake bolt shears off | Jack Glendening[_2_] | Soaring | 25 | September 10th 07 10:15 PM |
