Hi Tim,
Go to the Flarm website and use the configuration tool https://flarm.com/support/tools-software/flarm-configuration-tool/. Log in if you have an account, if not, it might be good to do so. Enter data applicable to your ship.Â* If I didn't know any better, I used the defaults.Â* After running the tool, the flarmcfg.txt file was downloaded automatically. Place the flarmcfg.txt file in the root of an SD card or USB stick whichever is applicable to your device.Â* Insert the device and power on your device.Â* After the configuration is complete, remove the device.Â* This should at least get you started.Â* I found initially that I got alerts on my own glider which was very distracting.Â* The fix was, IIRC, to go back to the default settings in the flarmcfg.txt file. That should get you started. Dan On 7/14/2019 1:16 PM, Tim Taylor wrote: Dan, please provide details of what you did. I have not had Flarm target ID’s on my Oudie since last August. I also can not add gliders to my buddy list. -- Dan, 5J |
flarm/oudie | [email protected] | Soaring | 3 | September 15th 17 02:51 PM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 3 | April 10th 16 04:13 AM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Noise issues with Oudie 2 in a couple different aircraft | Doug Mueller | Soaring | 15 | July 25th 14 02:22 PM |
Oudie Issues | vontresc | Soaring | 4 | July 16th 14 04:44 AM |
