I have been having almost the same issue and posted about it a few weeks back. I seem to display all flarm targets but only show their ICAO hexidecimal code, not their ID from the flarmnet database. When I ran XC soar on my Oudie with the propper flarmnet data set active, the targets and IDs were displayed perfectly, leading me to believe this is a problem with the current Oudie firmware. I have reached out to Naviter who has not provided a solution. I will reset my FLARM and post my results here.
It's known Oudie bug, no other possibilities than wait for a fix.
Latest Oudie update shows IDs.
Current FlarmNet download page: LXNAV and Naviter 20190715.fln Copy to RADAR folder |
On Monday, July 15, 2019 at 9:53:44 AM UTC-6, George Haeh wrote:
Latest Oudie update shows IDs. Current FlarmNet download page: LXNAV and Naviter 20190715.fln Copy to RADAR folder George, Please post what version of the SeeYou software you are using. I am using 9.15.01 and could not see Flarm ID's last week. Tim |
On Monday, July 15, 2019 at 9:04:52 AM UTC-7, Tim Taylor wrote:
On Monday, July 15, 2019 at 9:53:44 AM UTC-6, George Haeh wrote: Latest Oudie update shows IDs. Current FlarmNet download page: LXNAV and Naviter 20190715.fln Copy to RADAR folder George, Please post what version of the SeeYou software you are using. I am using 9.15.01 and could not see Flarm ID's last week. Tim I also can not see Contest IDs. SeeYou PNA9.15.001 20190715.fln Bench Testing with two PowerFlarm units and Ultimate running SeeYou PNA 9.15.001. Richard www.craggyaero.com |
Contest ID not showing is unlikely an issue with the powerflarm but with your display. Since most complaints are about the Oudie I suspect the issue is with the Oudie, or the flarmnet file (wrong format perhaps)?
I don’t have these issues with latest firmwares neither in Xcsoar nor LX9000. The only contest ID not showing is for those which have yet to enter their info on flarmnet (nearly half the pilots apparently find it too challenging). Reception vary significant between installations, some show up 5 miles while others less than a mile. If you see someone consistently from more than 5 miles you most likely see their ADSB signal, not flarm signal (the target will look exactly the same in some displays). Ramy |
Running 9.15.001
Settings - Flarm brings up: Settings - Radar page Labels Show box is checked. The IDs were not showing just before the 9.15 upgrade |
On Tuesday, July 16, 2019 at 3:03:22 AM UTC-4, Ramy wrote:
Contest ID not showing is unlikely an issue with the powerflarm but with your display. Since most complaints are about the Oudie I suspect the issue is with the Oudie, or the flarmnet file (wrong format perhaps)? I don’t have these issues with latest firmwares neither in Xcsoar nor LX9000. The only contest ID not showing is for those which have yet to enter their info on flarmnet (nearly half the pilots apparently find it too challenging). Reception vary significant between installations, some show up 5 miles while others less than a mile. If you see someone consistently from more than 5 miles you most likely see their ADSB signal, not flarm signal (the target will look exactly the same in some displays). Ramy Any tips on how to record the FLARM IDs seen in flight if the contest ID is not available (missing from FlarmNet data)? It's a hassle to write them down by hand, but they are not recorded in the flight log (except perhaps in the encrypted LFLA lines). I wish my glide computer (Tophat) would let me add the ID seen to the data file with one tap, then I can try and add the contest ID to it later. |
flarm/oudie | [email protected] | Soaring | 3 | September 15th 17 02:51 PM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 3 | April 10th 16 04:13 AM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Noise issues with Oudie 2 in a couple different aircraft | Doug Mueller | Soaring | 15 | July 25th 14 02:22 PM |
Oudie Issues | vontresc | Soaring | 4 | July 16th 14 04:44 AM |
