#11
On Wednesday, December 5, 2012 11:55:17 AM UTC-7, JS wrote:
Going by just tail weight, perhaps Martin Heide has friends who are chiropractors. I suspect Martin just inherited this design feature. My 28 runs about 60lb on the tail, ballasted and with me in the cockpit. I have to lift a lot more than that to put the tail dolly on. I have no record of the tail weight for that condition but it calculates to approx 90lb. Attempting to answer the OP's question - In specified weighing attitude, no ballast and no pilot, tail 67lb. Same with pilot and chute in cockpit, tail 37.5lb. As others have pointed out, the conditions for measuring tail weight have a huge influence on the result. No data will be of any value unless the conditions are specified. Andy (GY) |
On Dec 6, 6:19*am, Andy wrote:
On Wednesday, December 5, 2012 11:55:17 AM UTC-7, JS wrote: Going by just tail weight, perhaps Martin Heide has friends who are chiropractors. I suspect Martin just inherited this design feature. *My 28 runs about 60lb on the tail, ballasted and with me in the cockpit. *I have to lift a lot more than that to put the tail dolly on. *I have no record of the tail weight for that condition but it calculates to approx 90lb. Attempting to answer the OP's question *- In specified weighing attitude, no ballast and no pilot, *tail 67lb. *Same with pilot and chute in cockpit, tail 37.5lb. As others have pointed out, the conditions for measuring tail weight have a huge influence on the result. *No data will be of any value unless the conditions are specified. Andy (GY) Janus C - 64 lbs Speed Astir II - 90 lbs |
ASW-19B = 70 lbs
LS8-18 = 67 lbs Both values without pilot or chute, and both done using manufacturer's specified tail position. -John |
DG-1000 109 lbs without tail weights and empty cockpits
THANKS ALL for your helpful info.
I was simply trying to determine if my glider had a typical tail wheel weight. The first time I tried to lift the tail to install a dolly I was dismayed to discover how heavy it is. All I had to compare it with is the club fleet of three SGS machines which all have very light tail weights. It seems as if the older gliders (Cherokee, 1-26, 1-34) are almost balanced on the wheel whereas the glass ships are quite heavy. Does this make them any trickier to land? I realize the flying balance is most likely different from wheel balance i.e CG and wheel are not co-located. The average of the single place tail weights without pilot aboard is 66 lbs. and mine is 72 lbs. so I am right in the ballpark. Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? |
I just risk my back. The Speed Astir 'Dolly' is just a post on a
wheel. That's nice, because you can't accidentally take off with it on, but lifting that 90 lb tail and trying to fit the post into the hole in the underside of the fuselage can be challenging. The Janus uses a conventional dolly and has only 64 lbs on the tailwheel. Piece of cake. BTW, on the subject of weight and balance, just for your own knowledge you might want to run the numbers with your tail dolly ON. In the case of the Janus, the glider remains well within CG limits unless it is being flown solo by a person that is lighter than me, or any of my partners. On Dec 7, 1:32*pm, soartech wrote: THANKS ALL for your helpful info. I was simply trying to determine if my glider had a typical tail wheel weight. The first time I tried to lift the tail to install a dolly I was dismayed to discover how heavy it is. All I had to compare it with is the club fleet of three SGS machines which all have very light tail weights. It seems as if the older gliders (Cherokee, 1-26, 1-34) are almost balanced on the wheel whereas the glass ships are quite heavy. Does this make them any trickier to land? *I realize the flying balance is most likely different from wheel balance i.e CG and wheel are not co-located. The average of the single place tail weights without pilot aboard is 66 lbs. and mine is 72 lbs. so I am right in the ballpark. Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? |
On Friday, December 7, 2012 4:32:41 PM UTC-5, soartech wrote:
Has anyone made a simple lever-lifted dolly arrangement? Of course: http://www.cobratrailer.com/catalog/...roducts_id=144 |
On Fri, 7 Dec 2012 13:32:41 -0800 (PST), soartech
wrote: .... text deleted Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? I'd recommend Mark Mocho's combination tow dolly with integrated lift bar. http://www.mmfabrication.com/towbars.htm A very satisfied user. Bob |
On Friday, December 7, 2012 2:32:41 PM UTC-7, soartech wrote:
THANKS ALL for your helpful info. I was simply trying to determine if my glider had a typical tail wheel weight. The first time I tried to lift the tail to install a dolly I was dismayed to discover how heavy it is. All I had to compare it with is the club fleet of three SGS machines which all have very light tail weights. It seems as if the older gliders (Cherokee, 1-26, 1-34) are almost balanced on the wheel whereas the glass ships are quite heavy. Does this make them any trickier to land? I realize the flying balance is most likely different from wheel balance i.e CG and wheel are not co-located. The average of the single place tail weights without pilot aboard is 66 lbs. and mine is 72 lbs. so I am right in the ballpark. Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? I agree with Bob's comment about Mark Mocho's tow bar and tail boom lifter. It works very well and there are at least 30 or 40 satisfied users at Moriarty and there are many other users around the US! His website is: www.mmfabrication.com |
THANKS ALL for your helpful info. I was simply trying to determine if my glider had a typical tail wheel weight. The first time I tried to lift the tail to install a dolly I was dismayed to discover how heavy it is. All I had to compare it with is the club fleet of three SGS machines which all have very light tail weights. It seems as if the older gliders (Cherokee, 1-26, 1-34) are almost balanced on the wheel whereas the glass ships are quite heavy. Does this make them any trickier to land? I realize the flying balance is most likely different from wheel balance i.e CG and wheel are not co-located. The average of the single place tail weights without pilot aboard is 66 lbs. and mine is 72 lbs. so I am right in the ballpark. Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? As weighed when I took delivery of my plane the tail wheel had 71 lbs on it. I added 6 lbs of ballast back there. When I'm in the plane the CG is about 7.5 inches behind the main wheel. Of course all this is with the plane leveled; since the plane normally sits tail down more weight shifts aft. The position of the CG is normal for these kind of tail dragger planes. Schweitzers (other than the 1-35) and typical glass trainers (K21 or G103) are nose draggers when occupied. What I do to put on or take off the tail dolly is to straddle the tail boom facing aft. After I pick up the boom I cross my ankles under the boom so I easily hold it up while messing with the dolly. -- Matt -- Matt |
ASK-21 Weight and Balance | Carl Baxter | Soaring | 4 | June 2nd 11 02:57 PM |
PA-32 Weight and Balance | John Doe | Owning | 14 | May 23rd 06 01:03 AM |
L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 01:54 AM |
Weight and Balance | Dale Larsen | Home Built | 2 | June 23rd 04 05:11 PM |
Weight and Balance | JP | Piloting | 2 | January 13th 04 10:54 AM |
