A Poll on your weight and balance
Old December 5th 12, 05:49 PM posted to rec.aviation.soaring
soartech
Default A Poll on your weight and balance
All sailplane owners,
Please reply with the weight on your tail wheel from your weight and
balance sheet. I will calculate the average after a few days and post
it and the range. Reply on this list or directly to me, either way is
fine.
Thanks.
Old December 5th 12, 06:26 PM posted to rec.aviation.soaring
Matt Herron Jr.
Ventus C (all up)
Nose wheel: 772 lbs
tail wheel 36.3 lbs
C/G 4.5" aft of datum (76% aft)
Old December 5th 12, 06:43 PM posted to rec.aviation.soaring
fine.
Thanks.
It would be nice to know what you try to accomplish. Also there are so many variables going into the tail wheel weight. A Genesis probably will be much different from a Duo Discus. You should also specify if this weight is for the empty glider or with the pilot and chute.
Old December 5th 12, 06:55 PM posted to rec.aviation.soaring
JS
Looking from a medical viewpoint?
Going by just tail weight, perhaps Martin Heide has friends who are chiropractors.
Old December 5th 12, 07:49 PM posted to rec.aviation.soaring
Tony[_5_]
Empty:
Std Cirrus - 65 lbs on tail
Cherokee II - ~25 lbs on tail
NG-1 - ~5 lbs on tail
Old December 5th 12, 10:04 PM posted to rec.aviation.soaring
Frank Whiteley
fine.
Thanks.
LAK12 empty
34.5kg 76lbs
Old December 5th 12, 10:29 PM posted to rec.aviation.soaring
C-FFKQ (42)
Kestrel 19
104 lbs on the tailwheel, empty
Can you say, "Oh, my aching back!"?
Old December 5th 12, 11:48 PM posted to rec.aviation.soaring
ASW-27b 23lb on tail. Dry no pilot.
Mosquito A 46lb on tail. Dry no pilot.
Old December 6th 12, 12:30 AM posted to rec.aviation.soaring
rlovinggood
1970 LS1-d
Empty
70.0 lbs
(31.75Kg)
With pilot on board, ready to fly:
48.0 lbs
(21.77Kg)
Old December 6th 12, 12:50 AM posted to rec.aviation.soaring
Papa3[_2_]
1978 Grob Twin Astir Serial Number 3075
Empty
Tail: 113.5
Main: 818
fine.
Thanks.
ASK-21 Weight and Balance Carl Baxter Soaring 4 June 2nd 11 02:57 PM
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 01:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
