A Poll on your weight and balance
Old December 8th 12, 03:36 AM posted to rec.aviation.soaring
Dave Nadler
Default A Poll on your weight and balance
On Friday, December 7, 2012 5:33:52 PM UTC-5, Dave Nadler wrote:
Of course:
http://www.cobratrailer.com/catalog/...roducts_id=144
PS: Tail weight of Antares 20E without pilot: 139 lbs.
This feature means that with pilot, under full power,
there is still adequate weight on steerable tail
wheel to provide excellent directional control during
initial take-off.
But don't try to lift the tail !
Old December 8th 12, 04:18 AM posted to rec.aviation.soaring
jfitch
On Wednesday, December 5, 2012 9:49:48 AM UTC-8, soartech wrote:
All sailplane owners,
Please reply with the weight on your tail wheel from your weight and
balance sheet. I will calculate the average after a few days and post
it and the range. Reply on this list or directly to me, either way is
fine.
Thanks.
154 lbs. on the tail wheel. Do I win a prize?
ASH26E, no pilot or wing ballast, 6 lbs of lead in the tail ballast box.
Old December 8th 12, 04:26 AM posted to rec.aviation.soaring
jfitch
fine.
Thanks.
I should also mention that, even so, I have little trouble putting the tail dolly on, I don't use a cheater bar, and I'm not superman. You just need to perfect your technique.
Old December 8th 12, 02:06 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
fine.
Thanks.
Just ask a friend to sit on your nose!
:) JJ
Old December 8th 12, 02:13 PM posted to rec.aviation.soaring
Dave Nadler
Really JJ, this is a family channel...
Old December 11th 12, 04:00 PM posted to rec.aviation.soaring
kirk.stant
fine.
Thanks.
:) JJ
Isn't that what a tail dolly is for?
66
Old December 14th 12, 02:01 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
6
When the tail of my sailplane is too heavy for me to lift, I ask a friend to sit on the nose and that makes the tail light enough for me to easily put on the tail dolly. Didn't think it was necessary to connect the dots when I made my suggestion, guess I was wrong.
JJ
Old December 14th 12, 10:37 PM posted to rec.aviation.soaring
GC[_2_]
6
connect the dots when I made my suggestion, guess I was wrong. JJ
It's OK, Kirk. It gave the rest of us a giggle.
GC
  #29
Old December 15th 12, 07:36 AM posted to rec.aviation.soaring
kirk.stant
6
GC
JJ, think "Doughnut Dolly"... ;^)
  #30
Old December 15th 12, 03:07 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
So now I'm going to ask a Doughnut Dolly to, "Sit on my nose"? I don't have a problem with that, but I bet wife Pat would be sitting on top of the volunteer dolly and I'd end up with a broken nose one way or the other. She has been known to engage in ramp sex..............you know where you stand nose to nose and scream FUC* YOU at each other!
:) JJ
ASK-21 Weight and Balance Carl Baxter Soaring 4 June 2nd 11 02:57 PM
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 01:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
