#31
On Friday, May 15, 2015 at 2:59:26 PM UTC-4, Bill D wrote:
Lets say you are deploying a retractible gear glider in a club with members who some might suspect of landing the thing gear-up someday. (Of course, you private owners never land gear-up...) Is there a way to minimize the damage when the inevitable day arrives? Maybe. One of my favorite materials is UHMW-PE - a plastic with many superlative characteristics including astonishing abrasion resistance and a very low coefficient of friction. A 9mm thick strip, 150mm wide might very well withstand a gear-up landing of an 850 kg glider. It's also very light, cheap and a shade of white closely matching gel-coat. Until recently, there was no way to glue this stuff to anything even itself but new epoxy adhesives have appeared on the market that advertize the ability to stick it to almost anything including fiber reinforced composite epoxy structures like glider belly's and wing tips. So, obviouisly, some testing is in order before slapping a strip of UHMW-PE on the belly of your glider. A test rig on a pick-up's reciever hitch could slam a patch of it down on a concrete runway to simulate a gear-up. Anybody interested? Bill, 3M offers a very thick PU-film tape used on the leading edge of helicopter blades and wind turbine blades (leading edge erosion tape). The adhesive is very sticky - I had it on the belly of my glider for 20+ years and it protected it from stone chips aft of the landing gear and an intentional gear-up landing in a freshly prepared cotton field. One could apply several layers for a 850kg ship. Uli |
#32
I've always presumed that real aviators can fly their aircraft and listen to the radio at the same time. If a "check gear" call rattles a pilot so that he loses control of the glider, there's a problem afoot much more serious than radio procedures. I agree! If I was going to land gear up would be nice to have a radio call from someone who noticed, I can certainly fly and listen to the radio. Hell, I even had tower tell me I was on fire right after I got in the air, no reason to crash. Once I did almost land gear up was flaring when I heard a call "gear" lowered the gear just in time, was low enough I scrapped the forward corner of both gear doors. Fly the aircraft and deal with the issue, no reason to have a moratorium on alerting a pilot on final. If the pilot does not have the skills to fly and solve a problem he should just fly then and maybe take up tennis. On a related point, checklists. Whether I am flying the Grob (fixed gear) or the Nimbus, I use the same checklist before every landing. Used a check list in the Turbo prop too. |
#33
There are two kinds of glider pilots: - Those of us that has landed gear up (and will eventually do it again). - And those of you who has not done done it, yet. When it comes to calling "gear up" on the radio do you have to bear in mind that cockpits in gliders are differently designed. On SH are the gear leveler on the right side and has to be pushed forward. So to extract the gear on short final means that you have to push the brake forward into locked position, change from right hand to left for the stick and then maneuver the gear with the right. On old SH is the force for maneuver the gear leveler significant and it is nog uncommon that you pull the stick backwards. You are now on a really short final with the stick in wrong hand, high nose attitude and no hand on the airbrake. Most of the time can we handle this, but sometimes is the stress to much. Before you call "gear up" on final in the radio do you therefore need to know: - Is the pilot mentally capable of the stress right now? My almost first gear up landing was in a Discus, someone called "Gear up" on short final and it was close to be the last landing of that Discus. My first gear up landing was in a LS1-f on bitumen, a big surprise for me that glider hit ground 2dm lover than expected and big amusement from the surroundings. It took med less than 3h in the workshop the same day to repair the damage and the glider was ready for competition the next day. When it happens again do I prefer the gear up scenario, even on a hard surface than fiddling with gear leveler on low altitude with a potential wreckage. |
#34
to the radio at the same time. If a "check gear" call rattles a pilot so that he loses control of the glider, there's a problem afoot much more serious than radio procedures. I agree! If I was going to land gear up would be nice to have a radio call from someone who noticed...snip...no reason to have a moratorium on alerting a pilot on final... In this case: "moratorium" = "catering to the lowest common denominator". First priority: Fly the stinking sailplane! Second priority?: (If you must...) Abuse it as gracefully as possible under the circumstances. Head shakingly, Bob W. |
#35
From where I fly:
- glider w/ gear up turning into final / on long final: Be nice and give him a radio call - glider (still?) w/ gear up on short final: Leave him alone. Make sure that the beer is in the cooler. Biggest damage will be the one to the driver's ego. Someone who is too distracted to prepare for landing will most probably fail to react to a buzzer or other onboard alarms, so I don't see the point of these gadgets. And somebody who just forgot to do the check - well, he won't next time. |
#36
The best idea I came across some years ago was at a flight school that trained in both fixed gear and retractable single-engine. The fixed-gear planes had a panel switch labeled "gear" with a red and green light. Gear down and locked was taught on every single flight in all their ships and became part of "muscle memory".
Mike |
#37
On Monday, May 18, 2015 at 1:55:27 AM UTC-6, Per Carlin wrote:
When it comes to calling "gear up" on the radio do you have to bear in mind that cockpits in gliders are differently designed. On SH are the gear leveler on the right side and has to be pushed forward. So to extract the gear on short final means that you have to push the brake forward into locked position, change from right hand to left for the stick and then maneuver the gear with the right. On old SH is the force for maneuver the gear leveler significant and it is nog uncommon that you pull the stick backwards. You are now on a really short final with the stick in wrong hand, high nose attitude and no hand on the airbrake. Most of the time can we handle this, but sometimes is the stress to much. Before you call "gear up" on final in the radio do you therefore need to know: - Is the pilot mentally capable of the stress right now? I fly an old S-H glider and this falls under the heading of basic airmanship. Switching hands on the stick is SOP for many operations. It behooves one to learn how to do it while flying accurately. |
#38
Le lundi 18 mai 2015 17:46:31 UTC+2, Bill D a écrit*:
On Monday, May 18, 2015 at 1:55:27 AM UTC-6, Per Carlin wrote: When it comes to calling "gear up" on the radio do you have to bear in mind that cockpits in gliders are differently designed. On SH are the gear leveler on the right side and has to be pushed forward. So to extract the gear on short final means that you have to push the brake forward into locked position, change from right hand to left for the stick and then maneuver the gear with the right. On old SH is the force for maneuver the gear leveler significant and it is nog uncommon that you pull the stick backwards. You are now on a really short final with the stick in wrong hand, high nose attitude and no hand on the airbrake. Most of the time can we handle this, but sometimes is the stress to much. Before you call "gear up" on final in the radio do you therefore need to know: - Is the pilot mentally capable of the stress right now? I fly an old S-H glider and this falls under the heading of basic airmanship. Switching hands on the stick is SOP for many operations. It behooves one to learn how to do it while flying accurately. Switching hands on the stick while working the airbrakes on short final is no SOP at all. Bert Ventus cM TW |
#39
On Monday, May 18, 2015 at 2:41:06 AM UTC-4, Jonathan St. Cloud wrote:
I've always presumed that real aviators can fly their aircraft and listen to the radio at the same time. Fly with the pilots that you have, not the pilots that you would like to have. The notable number of fatal accidents attributed to pilot panic and/or misstep triggered by a panicky radio call is evidence that radio calls on short final (and takeoff) are rather risky. Some of those accidents involved very seasoned pilots. You'll never know which pilot will be distracted until it happens. It might be a low hours pilot, or it might be a high hours pilot that is tired or past his prime (or both). That the gear is up or the tail dolly left on in the first place is a clear indication of pilot brain fart, and one brain fart flags the risk of an adverse reaction to a radio call. The BGA rule against this sort of radio call is an interesting counter balance to the consensus of RAS pundits in favor of short final/takeoff radio calls. A pilot who is not sure how he would react has the option of turning off his radio at some point. |
#40
Also a pilot that does not have the skills to address the emergency at low altitude has the option of just landing gear up. I am of the belief knowledge is good, what you do with it is TOTALLY up to you.
| Thread Tools | |
| Display Modes | |
| Remove layer of cloth/Gelcoat | glider[_2_] | Soaring | 1 | February 9th 10 08:39 PM |
| Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (0/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 08:31 PM |
| Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 08:31 PM |
| composite using aluminum windowscreen layer | Allan Morrison | Home Built | 4 | January 27th 05 02:19 PM |
| sacrificial aluminum | Rob | Home Built | 1 | July 12th 04 10:45 PM |
