Sacrificial layer for gear-up protection.
Old May 15th 15, 07:59 PM posted to rec.aviation.soaring
Bill D
Default Sacrificial layer for gear-up protection.
Lets say you are deploying a retractible gear glider in a club with members who some might suspect of landing the thing gear-up someday. (Of course, you private owners never land gear-up...) Is there a way to minimize the damage when the inevitable day arrives?
Maybe. One of my favorite materials is UHMW-PE - a plastic with many superlative characteristics including astonishing abrasion resistance and a very low coefficient of friction. A 9mm thick strip, 150mm wide might very well withstand a gear-up landing of an 850 kg glider. It's also very light, cheap and a shade of white closely matching gel-coat.
Until recently, there was no way to glue this stuff to anything even itself but new epoxy adhesives have appeared on the market that advertize the ability to stick it to almost anything including fiber reinforced composite epoxy structures like glider belly's and wing tips.
So, obviouisly, some testing is in order before slapping a strip of UHMW-PE on the belly of your glider. A test rig on a pick-up's reciever hitch could slam a patch of it down on a concrete runway to simulate a gear-up. Anybody interested?
Old May 15th 15, 08:31 PM posted to rec.aviation.soaring
Bill,
Could you provide the brand name of the particular epoxy that will stick to this stuff? I would like to install a couple strips to the down-turned wing tip skids on my LS-3. The design of the tips makes it difficult to use mechanical fasteners.
Ron C.
Old May 15th 15, 08:36 PM posted to rec.aviation.soaring
son_of_flubber
I've seen this eventuality addressed on an L-23 by putting a ziptie around the gear lowering handle.
Old May 15th 15, 08:42 PM posted to rec.aviation.soaring
Bill D
On Friday, May 15, 2015 at 1:31:32 PM UTC-6, wrote:
Bill,
Ron C.
Here's one - there are dozen more.
http://reltekllc.com/adhesivesforuhmw.aspx
Just Google "uhmw-pe epoxy adnesive"
Old May 15th 15, 10:29 PM posted to rec.aviation.soaring
Bob Pasker
all of the club retracts I've flown have had the handle disabled, either with a ziptie or with safety wire
Old May 15th 15, 10:54 PM posted to rec.aviation.soaring
While a "sacrificial layer" seems good, best method I've seen is to have the offender help with doing the repairs.
Granted, it means some glider downtime, but "word of mouth" goes miles as a reminder.
Since I tend to do "final finish & polish", I have a vested interest in what happens to ships.
[yes, UHMW-PE is a great material, even "good" adhesives are short term in my eyes.]
Old May 15th 15, 11:22 PM posted to rec.aviation.soaring
Bill D
I don't think that's going to work with a Discus
Old May 15th 15, 11:23 PM posted to rec.aviation.soaring
Mike the Strike
Disabling an aircraft control sounds not only insane but likely also illegal.
Old May 15th 15, 11:25 PM posted to rec.aviation.soaring
Bill D
On Friday, May 15, 2015 at 3:54:17 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
Much better to just put the glider back on its wheel and go fly. Usually the offender is sufficiently embarassed.
Are you saying the UHMW-PE adhesives don't really last?
Old May 16th 15, 04:32 AM posted to rec.aviation.soaring
Bill T
Not the best idea for a Club LS4 going cross country.
BillT
Remove layer of cloth/Gelcoat glider[_2_] Soaring 1 February 9th 10 07:39 PM
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
composite using aluminum windowscreen layer Allan Morrison Home Built 4 January 27th 05 01:19 PM
sacrificial aluminum Rob Home Built 1 July 12th 04 09:45 PM
