Non-published hold with Garmin 430W
Old November 25th 09, 02:24 PM posted to rec.aviation.ifr
Evan Salant
Default Non-published hold with Garmin 430W
There's not a lot in the user's manual about how to set up a non-
published hold using the Garmin 430W. Lets say you are on a
flightplan with SBJ VOR as one of your waypoints and ATC needs you to
hold on the SBJ 160 radial right hand turns one minute legs. Is
there anything to simplify this other than setting up direct to the
VOR and using the OBS button and setting the OBS indicator on 340
degrees (inbound heading) ? Any other tricks ?
Evan
Old November 25th 09, 03:09 PM posted to rec.aviation.ifr
published hold using the Garmin 430W. *Lets say you are on a
hold on the SBJ *160 radial right hand turns one minute legs. *Is
degrees (inbound heading) ? *Any other tricks ?
Evan
Never done this myself Evan, but if I had to think on the "fly"
literally and figuratively, can you set up a "flight plan" of SBJ to
SBJ160002 in the flight plan option of the 430 (I don't have the W
flavor but this shouldn't be a factor)
Going on memory, SBJ is the VOR, 160 is the radial and 002 is the
miles out on the 160 radial (2 miles a minute) I believe you can set
up the 430 with radials and DME but I haven't done this in the
practical world. If my concept is right at least the length of the
outbound track will be displayed on the map display.
Garmin 430W autopilot operation Glasair470 Instrument Flight Rules 7 January 17th 08 12:37 PM
Garmin 430W holding help? Paul kgyy Piloting 1 April 10th 07 11:36 PM
XM Wx Garmin 430/430W with Garmin GDL-69? [email protected] Instrument Flight Rules 4 March 5th 07 03:52 AM
Garmin 430W/530W first impressions Viperdoc[_4_] Instrument Flight Rules 9 February 27th 07 02:10 AM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
