need source for replacement struts for Komet III Trailer
Old October 6th 12, 11:34 PM posted to rec.aviation.soaring
Default need source for replacement struts for Komet III Trailer
I need to replace the air struts for a 1982 15 Meter Komet III Trailer.
Any suggestions for sources?
jcmartin AT bak.rr.com
Old October 7th 12, 05:06 PM posted to rec.aviation.soaring
Dan Marotta
If you're in the US, you might try McMaster Carr. I got struts for the
front door of my LAK trailer at significant savings over ordering from
Europe. I just measured the strut (extended and collapsed) and read the
force off the side of the old strut. I was unable to get an exact match so
I ordered two that were slightly stronger. They work just fine.
Old October 16th 12, 07:21 PM posted to rec.aviation.soaring
I haven't researched where to buy, but a friend of mine replaced his with the following:
Bansbach easylift
QS-28-350--001 1300N
He had tried a heavier spring force but found it too hard for his wife to close the trailer and replaced them with the 1300N struts.
Morgan
Old October 17th 12, 12:14 PM posted to rec.aviation.soaring
Clay[_4_]
McMaster Carr also has adjustable ones that are excellent (and made in England!).
Komet trailer damper replacement Wheaton Soaring 3 June 28th 12 02:29 AM
trailer lift struts dinoa Soaring 1 September 28th 09 04:23 PM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Komet Trailer gas struts HL Falbaum[_2_] Soaring 13 February 1st 09 01:05 PM
Gas Struts for Clamshell Trailer [email protected] Soaring 1 April 26th 05 02:49 AM
