Jockey wheel for PIK-20 trailer
Old November 18th 12, 04:13 PM posted to rec.aviation.soaring
lynn
Default Jockey wheel for PIK-20 trailer
My PIK-20 trailer jockey wheel needs replacement but cannot find any commercially available units which will fit. The shaft size needs to be 40mm to fit the built-in clamp system. I do not want to install a side mount clamped to the side as it will induce too much twist into the frame. Any working used units out there that will fit?
Old November 23rd 12, 07:16 AM posted to rec.aviation.soaring
bumper[_4_]
In the US a "jockey wheel" is most often referred to as a trailer jack. I Googled "jockey wheel 40mm" and came up with this:
http://www.camperlands.co.uk/metal-j...mbly-40mm.html
good luck,
bumper
Cobra Trailer Replacement Wheel Chip Bearden Soaring 5 September 29th 09 08:35 PM
Komet trailer wheel bearings Dan[_6_] Soaring 7 February 9th 09 06:13 AM
truck + 5th wheel RV + glider trailer ?? Steve Koerner Soaring 16 March 27th 07 03:44 AM
Avionic trailer wheel needed qflyer1 Soaring 6 December 7th 06 03:30 PM
Q about trailer wheel bearings Ken Ward Soaring 1 September 15th 06 02:40 AM
