My Engine Fire!!
Old March 30th 04, 01:01 PM
kat
Default My Engine Fire!!
is this your plane or hired? either way you should know if there is a
fire extinguisher on board and if there is....where it is.
the 150 i fly will start with 1 prime on a hot day or none at all if it
has been flown within the past hour. on a cold day 2-3 primes is
enough.
good job on not freaking out though and staying on the ground!
kat
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Old March 30th 04, 03:02 PM
Dave Stadt
My O-200 starts on a half prime on cold days. According to the book the
prop should be turning when the primer is pushed in. They prime just above
the carb venturi. Pumping 3 to 4 shots without having the engine turning is
asking for trouble. Fuel dribbles out the carb into the airbox and the
cowl. One backfire and the entire engine compartment can be on fire.
"kat" wrote in message
enough.
kat
fly -
Old March 31st 04, 04:14 PM
Dan Thomas
Canadian aircraft are required, by law, to carry fire extinguishers. I
checked the US FARs but couldn't see that an extinguisher is required.
However, a $30 extinguisher could save your life, not to mention the
airplane. It's one of those things that many pilots don't worry about
until they need it, and then the cost of the item seems small indeed.
(Another example: a functioning ELT when the search planes are passing
by, and you realize that you've bought the farm because you didn't
bother keeping up the maintenance on it. Or it wasn't switched on to
"arm;" again, due to lousy maintenance. It has happened numerous times
up here.)
As for engine fires, the POH has all the info on such emergencies.
In Canada, a pilot is required at test time to know that book
thoroughly. It could save his life if he had an inflight fire, an
electrical fire or failure, and so on. Early POH's had no or very
little info on emergency procedures, until manufacturers started
getting sued half to death over people that died because they did the
wrong things. Now, with most airplanes built since the mid-70s, there
isn't any excuse not to have the info, except maybe not living long
enough to read the whole thing :-)
Dan
Old April 1st 04, 12:32 AM
Dave Stadt
Actually a cheap fire extinguisher will probably destroy your airplane. The
dry chemical is extremely corrosive and insurance companies will total the
plane rather than pay big bucks attempting to have it removed
"Dan Thomas" wrote in message
om...
up here.)
Dan
Old April 1st 04, 03:31 AM
C J Campbell
om...
airplane.
The only fire extinguisher worth having on your plane is halon. The US does
not require you to carry a fire extinguisher.
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
p3/95 [email protected] Military Aviation 1 September 27th 04 12:27 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
My Engine Fire!! [email protected] Piloting 21 April 2nd 04 05:02 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
