Check your rudder cables!
Old October 19th 13, 06:51 AM posted to rec.aviation.soaring
Ramy
Default Check your rudder cables!
We just had another rudder cable failure at the junction with the pedal S tube. Luckily this time it happened in a two seater and resulted in lost of rudder control only for the back seat PIC. Fortunately the front seat passenger was also a licensed pilot and could continue flying the glider, but not before they momentarily considered bailout until they realized the front seat still had full control.
A similar incident in a single seater last year resulted in a bailout. Due to the pedal spring, a cable failure may result in a full opposite rudder and unrecoverable spin/spiral.
It will be a good idea to inspect this area often, and even adjust the rudder pedal back and forth to expose and inspect more cable. At least in some models there should be a plastic sleeve to protect the cable there.
Ramy
Old October 19th 13, 12:05 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
t=
of
passe=
no=
front
seat still had full control. =20
Due
a=
nd unrecoverable spin/spiral.=20
rudd=
some
Type of glider please?
models there should be a plastic sleeve to protect the cable there.=20
Ramy
Old October 19th 13, 05:00 PM posted to rec.aviation.soaring
Ramy
Schleicher. But most gliders nowadays using the same rudder pedal adjustment mechanism using S tube. My 27 has plastic cover where the cable enters the S tube.
Ramy
Old October 19th 13, 06:58 PM posted to rec.aviation.soaring
Eric Munk
http://www.onlinecontest.org/olc-2.0...l?dsId=3402451
says ASH-25.
BTW: Most glassfibre Schleichers have a mandatory 3000-hour life on rudder
cables (and some others), that is taken up in the 3000-hour inspection
program. I find that this gets overlooked sometimes by owners
unintentionally, not insinuating that is what happened here.
Old October 20th 13, 05:23 AM posted to rec.aviation.soaring
Mike the Strike
Occasional inspection of rudder cables is not a bad idea. Some decades ago, I severed my rudder cable at a point where it passed along the cockpit in a tube in the sidewall with an errant screw when installing a boom mike. When the repair shop pulled out the cable, they found almost identical damage a few feet back in the fuselage caused by the factory! I had been flying it for over a year with just a couple of strands left.
Old October 19th 13, 06:06 PM posted to rec.aviation.soaring
Jim White[_3_]
I don't understand? Are the front pedals not connected to the back ones and
the back ones connected to the rudder? Which model of Schleicher glider
please.
t=
of
passe=
no=
front
Due
a=
rudd=
some
Ramy
Question On Rudder Cables [email protected] Soaring 3 June 24th 12 02:32 PM
Pretensioning cables Gig 601Xl Builder Home Built 18 December 1st 08 10:22 AM
Pegasus Rudder Cables? Bill[_9_] Soaring 10 June 28th 07 07:43 AM
unsticking cables dlevy Owning 12 January 8th 06 09:39 AM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
