Vacuum pressure
Old May 30th 04, 02:35 PM
Peter MacPherson
Default Vacuum pressure
At what rpm do people see their vacuum pressure drop below an acceptable
level(3.2?).
I also have a standby vac with a low vac pressure red warning light. When I
reduce power
to 1200-1300 rpm the vac pressure drops off and the red light comes on. I
thought in the
past the pressure would hold until around 1000 rpm. Does this seem to be
working properly?
TIA,
Pete
Old May 30th 04, 02:54 PM
Karl Treier
Most of the 172R's I have flown don't show Vacuum in the green below 1200
rpm.
Old May 30th 04, 04:48 PM
G.R. Patterson III
level(3.2?).
reduce power
thought in the
working properly?
That's about the same as my Maule ('cept I don't have a warning light).
George Patterson
None of us is as dumb as all of us.
Old May 30th 04, 09:19 PM
Louis L. Perley III
"Peter MacPherson" wrote in message
newsqluc.14569$3x.7535@attbi_s54...
level(3.2?).
I
reduce power
thought in the
working properly?
TIA,
Pete
I don't get into the green on my C152 until I'm at 1200 RPM or so, but
some of the 172's at the local flight school will hold 5 at 1000 RPM just
fine.
Louis L. Perley III
N46000
Vacuum pressure Peter MacPherson Instrument Flight Rules 1 May 30th 04 04:01 PM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 08:35 PM
Vacuum "pressure" for gyros Jari Kaija Home Built 3 March 18th 04 05:08 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
