Static system solution
Old April 24th 15, 04:19 PM posted to rec.aviation.soaring
Mark628CA
Default Static system solution
While replumbing my glider's static system, I got frustrated chasing down leaks in the myriad Tee connectors and joints. With the ASI, Altimeter, Transponder encoder and Cambridge 302 all on the system with two forward and two aft static ports, there were over thirty potential leak points. I did a little online search and found a pretty neat solution- a one inlet, six outlet tubing manifold. (It also comes in four, eight and twelve outlets.) Its purpose is an air supply splitter for the aerators in fish tanks. Cost was under six bucks delivered, and it works great! I cut out twelve tube junctions, and the installation is a lot cleaner.
The inlet tube is 3/8 inch and the outlets are 1/4 inch. I had to make an adapter for the inlet, but there are some available from McMaster. Mine is one piece, but you might have to thread a male/female pair together to get different tube sizes.
Anyway, I thought it was pretty cool:
http://www.amazon.com/Aquarium-Contr...arium+splitter
Old April 24th 15, 06:22 PM posted to rec.aviation.soaring
Nick Kennedy
Sounds like MM's hanger is a good place to take a leak--
or maybe a whole bunch of leaks
Kegeratoer anyone?
OLC Solution for Cambridge GPS-Nav Evan Ludeman[_4_] Soaring 5 September 18th 12 08:21 PM
System Operation of Aircraft System [email protected] Instrument Flight Rules 1 October 12th 07 06:50 AM
My static system had a leak Derrick Early Instrument Flight Rules 1 August 25th 04 02:35 PM
Roving static system check A&P Javier Henderson Owning 1 March 28th 04 09:36 PM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
