Downloading Xcsoar maps onto Dell Streak 5?
Old November 2nd 15, 09:20 PM posted to rec.aviation.soaring
pjschae
Default Downloading Xcsoar maps onto Dell Streak 5?
I am new to Android and XCsoar. I have XCsoar loaded on the Streak and I have tried to download a map from the XCsoar site but I get the error: "Cannot Download. The content is not supported on this phone." I tried the standard map and the Altair but no luck with either. What am I missing here?
Old November 3rd 15, 12:24 AM posted to rec.aviation.soaring
Dan Marotta
Try downloading to a PC and then copy to your XCSoardata folder on the
Streak.
Dan, 5J
Old November 3rd 15, 03:25 AM posted to rec.aviation.soaring
pjschae
I've downloaded the maps to my pc but I can't open the streak folders to copy them to. I've downloaded a driver from dell but I'm still not getting into the streak via my pc. Do have a link for a windows pc that will get me into the streak?
Old November 3rd 15, 01:49 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Put them on the microSD card in the Streak (remove card and put it in your PC). If you do not have one, get a microSD card for your Streak...
Old November 3rd 15, 04:17 PM posted to rec.aviation.soaring
Dan Marotta
When you connect the Streak to the PC, you'll get an alert in the top
line of the Streak. Pull down and you'll see a couple of notifications
about the USB connection. I don't remember the correct verbiage, but
select something like "Connect to USB for file transfer" and then "OK".
You should then get a popup on your PC about a removable drive. Open
Windows Explorer and select the removable drive. It should open in your
XCSoardata folder. Copy your file(s) there. Be sure to "Safely Remove"
the removable disk first and then turn off USB storage on the Streak.
If you don't do it in that order, the SD card not will be accessible to
the Streak. Or, if you have an SD card reader, remove the SD card from
the Streak, plug it into your PC, and copy your maps.
Hope that helps.
Dan, 5J
Old November 3rd 15, 10:29 PM posted to rec.aviation.soaring
pjschae
Thanks for the detailed reply. It worked!
ERIXX to Dell Streak via Bluetooth [email protected] Soaring 2 November 12th 14 10:01 PM
Dell Streak - what ROM version? [email protected] Soaring 7 May 24th 14 05:09 PM
Temperature Probe for Dell Streak Dan Marotta Soaring 14 April 20th 13 02:56 AM
Dell Streak 5 available soartech[_2_] Soaring 0 November 14th 12 05:44 PM
Short review of the Dell Streak with XCSoar Max Kellermann Soaring 6 February 9th 11 04:22 PM
