Motor Glider Becker Radio Set Up
Old September 7th 16, 11:15 PM posted to rec.aviation.soaring
6X
Default Motor Glider Becker Radio Set Up
Does anyone have experience and can recommend Becker radio (6201) configuration settings to allow for both use of a boom mic / speaker and headset connections? I have the boom mic / speaker working well but cannot transmit / receive in the headset.
Thanks.
Jeff R.
Old September 7th 16, 11:48 PM posted to rec.aviation.soaring
JS
Wasn't there a recent thread about this?
With a Becker 6201 in an ASH26E I have wired both ring and tip of an 1/8" jack in parallel with the speaker and plugged earbuds in. Used the existing gooseneck mic, which works great.
Old September 8th 16, 12:26 AM posted to rec.aviation.soaring
There is an installation manual for the AR6201, available online, that has this information in detail (section 2-7). It's hard to give more specific advice because there are both wiring and software configuration options that interact and have to be set properly. In my motor glider this is ultimately controlled by a panel switch that specifies which mic is active. It seems to work well.
Motor Glider Becker Radio Set Up 6X Soaring 0 September 7th 16 11:08 PM
Battery for Becker radio HGXC[_2_] Soaring 4 June 4th 14 12:06 AM
Becker Radio Repair Steve Leonard Soaring 2 August 23rd 05 05:00 PM
Becker radio repair Steve Leonard Soaring 2 August 23rd 05 02:25 AM
Becker radio AD Tom Serkowski Soaring 3 November 2nd 04 01:43 AM
