Single vs Double flared tubing
Old July 19th 04, 02:29 AM
Craig Foster
Default Single vs Double flared tubing
Do aluminum aircraft fuel lines need to be double flared for AN fittings (37
degree flaring)? There is a significant difference in cost between a single
and double flaring tool. I ran across this in Car Craft magazine:
"Most tubing in the aircraft industry is extruded in one piece with no seam,
so double flares aren't required to prevent crack formation."
Old July 19th 04, 02:53 AM
jls
"Craig Foster" wrote in message
news:BtFKc.126936$Oq2.10649@attbi_s52...
(37
single
seam,
The Parker flaring tool we use here makes burnished, deburred 37 degree
single flares in aluminum tubing used for fuel and hydraulic lines. It is
easy to use and quite precise.
I have made double flares with an SAE 45 degree tool and copper tube, which
is legal for some fuel lines on old airplanes like Cubs and Taylorcrafts.
The flares are pretty, hell on the forearm tendons when you're making them,
and hold up well, but are unnecessary.
I have heard of double-flare 37 degree flaring tools but never used one.
I have seen kits for complex airplanes with compression fittings for the
hydraulic lines. Whenever an A&P sees them he usually begins to slobber
like Pavlov's dog. Except the sentiment is not hunger, but anger.
37 Degree Single vs Double Flared Tubing Craig Foster Home Built 1 July 21st 04 03:24 PM
source for aluminum tubing with rounded corners? Kyler Laird Home Built 3 June 1st 04 03:07 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 07:31 PM
