Fastening Flexible Solar Panels to a trailer-what adhesive to use ?
Old June 10th 19, 04:08 PM posted to rec.aviation.soaring
Default Fastening Flexible Solar Panels to a trailer-what adhesive to use ?
Looking to add solar charging to my trailer by using flexible solar panels.
Would rather not drill through the Aluminum top.
Any experience with adhesives to use ?
Dan
Old June 11th 19, 12:31 AM posted to rec.aviation.soaring
TravisBrown73[_2_]
There are no adhesives that I know of that would be road-reliable (read, "Not going to kill someone by having a panel blow off at freeway speed")for any amount of time. You would be opening yourself up to a lot of liability there. I wouldn't even try it.
Old June 11th 19, 12:46 AM posted to rec.aviation.soaring
Mark Morwood
Dan
Here are a couple of different approaches used for RV's and caravans:
https://www.solar4rvs.com.au/solar-i...dhesive-tapes/
https://www.batterybusiness.com.au/b...e-solar-panels
Old June 11th 19, 02:05 AM posted to rec.aviation.soaring
Don't think a trailer mounted solar panel is going to "kill" anyone if it blows off, even at freeway speeds. Think of something like a 18" by 18" piece of corrugated cardboard. It's not like a piece of foam breaking off the Shuttle external tank and hitting at 545 mph (877 kmh).
Old June 11th 19, 02:11 AM posted to rec.aviation.soaring
Plus, I can highly recommend 3M VHB tape. I know of several trailer manufacturers that bond entire sheets of aluminum siding to the internal frame using nothing but VHB tape. You cannot separate (peel) a 1"x1" sample piece bonded to two pieces of Mylar using all your strength. Try it. Tough stuff!
Old June 11th 19, 03:57 PM posted to rec.aviation.soaring
bumper[_4_]
VHB will work.
I installed four 100 watt panels on my motorhome using polyurethane caulk to mount 1-1/2" aluminum angle on the short dimension. Panels are bolted to that so there is no roof penetration. That was 13 years ago and they are still solid.
Used the same method for mounting a panel on my Cobra aluminum top. Note this is a rigid, glass glazed panel which would be exposed to far more stress than a flexible panel. The mount is quite permanent, so I prefer not to mount the panel directly in case it needs to be replaced at some point.
Old June 11th 19, 04:48 PM posted to rec.aviation.soaring
Bumper,
On the Cobra trailer, what did you do with the wires coming out of the panel ?
Dan
On Tuesday, June 11, 2019 at 10:57:33 AM UTC-4, bumper wrote:
VHB will work.
Old June 11th 19, 04:51 PM posted to rec.aviation.soaring
Thank you all for the great advice.
Looks like 3M VHB #4991 is the way to go. Also, I was advised to add a twinwall polycarbonate pieces undeneath the panel, to keep the panel cool.
Dan
Old June 11th 19, 05:35 PM posted to rec.aviation.soaring
Papa3[_2_]
Spaceships and aircraft yes. Trailer at highway speeds, no?? :-)
There's a whole world of adhesives out there that don't come from Home Depot...
https://www.masterbond.com/industrie...space-industry
Above is tongue-in-cheek. As others have said, 3M VHB is widely available and has peel strengths way in excess of any mechanical or aerodynamic load you could put on the panels.
P3
Old June 11th 19, 10:17 PM posted to rec.aviation.soaring
Should the paint be stripped off of the surface before using the adhesive? I've seen very impressive adhesive mounts fail - not due to issues with the adhesive but with the paint that the adhesive was sitting upon debonding from the base metal. I assume that would be in play in this scenario as well, no?
Robert
P3
Sale today on 12 Volt flexible solar panel Soartech Soaring 40 December 1st 16 05:54 PM
Flexible solar panel deal Soartech Soaring 5 June 15th 16 08:26 PM
Strobl-Solar: questions about panels, wiring, and switching [email protected] Soaring 2 March 19th 14 09:43 PM
Batteries, Solar Panels, Transponders, etc. JS Soaring 7 August 31st 06 09:12 PM
Thin flexible solar panels Eric Greenwell Soaring 11 November 28th 03 04:35 PM
