LS8 ballast system plug spare part
Old January 12th 21, 02:24 PM posted to rec.aviation.soaring
Denis GUERIN
Default LS8 ballast system plug spare part
Hi everyone,
I am looking for the LS8 ballast system plug rubber ring that seal the plug when ballasting LS8s. This rubber ring expands in the wing hole when teflon crown is "screwed".
Does anyone know when to find this except from DG and their service contract ?
All the best for 2021,
Denis
Old January 13th 21, 03:44 PM posted to rec.aviation.soaring
Papa3[_2_]
On Tuesday, January 12, 2021 at 9:24:11 AM UTC-5, wrote:
Hi everyone,
Denis
I know I lost one when I owned an LS8 and I replaced it with an off-the-shelf piece from an industrial supply house. I can't imagine it is a custom-made part. I just took the dimensions (inner diameter, outer diameter, thickness) and started googling. This is probably 10 years ago or more, and I can't find the order right now, but I'll post here if I do.
Old January 13th 21, 03:47 PM posted to rec.aviation.soaring
Papa3[_2_]
Hi everyone,
Denis
Just for one example: https://www.mcmaster.com/rubber-gask...-pipe-gaskets/
I'm sure metric equivalents are out there. The other simple option is to buy some rubber gasket material (sheet) and cut your own.
Looking for water ballast system for DG 200 complete and or parts of. Chris Stratton Soaring 4 February 11th 20 08:31 PM
ASW 17 water ballast system OregonGliderPilot Soaring 2 August 18th 19 04:55 PM
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 1 March 30th 11 02:30 PM
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 3 March 28th 11 08:51 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
