Well got everything plumbed the other day and need
to wire the entire electrical system...not a whole lot to do really New 12v 9.0 amp battery 5 and 3 amp Klixon Breakers for the Tasman and the Microair 760 Aux. Power source Car Cig type plug-in Bus Bar Master Switch PTT Switch Microphone and speaker In-line fuses Anyone out there got any sage advice? Drawings of simple wiring diagrams they can email me or links to sites? Wiring, Seals, W&B, Annual and FLY... Thanks... Beach |
On Dec 11, 5:35 am, Travis Beach
wrote: Well got everything plumbed the other day and need to wire the entire electrical system...not a whole lot to do really New 12v 9.0 amp battery 5 and 3 amp Klixon Breakers for the Tasman and the Microair 760 Aux. Power source Car Cig type plug-in Bus Bar Master Switch PTT Switch Microphone and speaker In-line fuses Anyone out there got any sage advice? Drawings of simple wiring diagrams they can email me or links to sites? Wiring, Seals, W&B, Annual and FLY... Thanks... Beach Only one battery not two? If you have two, you can choose if you want each instrument to be individually switcheable. Battery connectors? XLRs seem to be the norm in the UK, and all the ones I've seen are 'made-up' with short leads to the XLRs and an in-line fuse and some duck tape to make sure it doesn't get tweaked. And I've seen a few gliders with a volt meter to show when the battery starts to fade. |
Take a look at the presentations on this topic from the 2007 SSA
convention at; http://www.geocities.com/jhderosa/av...presentations/ As always here are my standard warnings/comments/prognostications... - You can't just throw anything that seems electrical into an aircraft and stay legal and/or safe. - There is no aviation aisle at the local Radio Shack, hardware or DIY store. - Know if your ship is standard certified or experimental and understand what you can do yourself versus what needs to be done or supervised by an FAA licensed technician. - Every battery should be fused. If you only have one fuse in the entire ship, it should be right at the battery. - Use Tefzel wire throughout. Speaker wire, lamp cord, 14 ga house wire, and/or doorbell wire (I have seen them all) are not to be used. Wings and Wheels is a good source for Tefzel. - While Klixon breakers (and resetable breakers in general) are great and widely used in powered airplanesl, unfortunately they loose 0.5Vdc to 1.0Vdc of your battery voltage. Fine if you have a generator putting out 13.6Vdc but not so wonderful with a fixed power source. See http://groups.google.com/group/rec.a...a192bb4955aa9b for more details. Fly Safe, John "67" DeRosa |
Very Good suggestions. And while you are at it, be prepared to spend
some serious $$ on the proper tools. I use nothing but AMP PIDG connectors crimped by a genuine APF PIDG Crimp tool. My tefzel wire is stripped using the correct mil spec stripper( Ideal Industries Custom Stripmaster(R) Wire Stripper 16-26 AWG wire Item ID:45-1987 http://www.idealindustries.com). Probably near $300 worth of tools there. Ideally, leave your soldering iron at home. I have a lot of AGW 20 and 22 in my glider. I spend the money to get it is WHITE (general use) BLACK (grounds) and RED (power). I am very capable of mis wiring things, so the red/black is a good visual check that I don't do something stupod. Most equipment should tolerate some mis-wiring as long as teh power and grounds are correct. Look at http://www.aeroelectric.com for some useful tips. His "The AeroElectric Connection" book is worth the price. Personally, I think Circuit Beakers look cool, but a standard fuse holder will get the job done. The only fuses I have blown were on the ground when I did something stupid. I probably have too many fuses in my glider and electric systems are a really good place to practice the KISS theory. I do have a large (10 A) fuse attached to the + terminal or both of my batteries. Big enough that I will never blow it with normal load and small enough that it will blow for some catastrophic problem. All my switches are SPDT (Single pole, double throw) (http:// en.wikipedia.org/wiki/Switch) with the L1/L2 poles going to Battery A/ B and the COM pole to the device. I can then select what battery each device (or group of devices) runs off of. I have (2) 12 AH Battery's and the radio is the big battery killer. If the battery gets low, I move the radio to the other battery (avoids a power cycle of my loggers). While on the subject...My switches are the only soldered connection in my glider and the only place where I have had a wring failure (due to vibration during trailering over 1000 miles). Proper strain relief is mandatory for all wiring harnesses. |
On Dec 11, 4:59 pm, Todd wrote:
Very Good suggestions. And while you are at it, be prepared to spend some serious $$ on the proper tools. I use nothing but AMP PIDG connectors crimped by a genuine APF PIDG Crimp tool. My tefzel wire is stripped using the correct mil spec stripper( Ideal Industries Custom Stripmaster(R) Wire Stripper 16-26 AWG wire Item ID:45-1987http://www.idealindustries.com). Probably near $300 worth of tools there. Ideally, leave your soldering iron at home. Oh, come on. Do you really think that the low temperature (compared to near a running engine) and low vibration environment of a glider requires such expensive connections ? Todd 3S |
On Dec 11, 6:51 pm, toad wrote:
On Dec 11, 4:59 pm, Todd wrote: Very Good suggestions. And while you are at it, be prepared to spend some serious $$ on the proper tools. I use nothing but AMP PIDG connectors crimped by a genuine APF PIDG Crimp tool. My tefzel wire is stripped using the correct mil spec stripper( Ideal Industries Custom Stripmaster(R) Wire Stripper 16-26 AWG wire Item ID:45-1987http://www.idealindustries.com). Probably near $300 worth of tools there. Ideally, leave your soldering iron at home. Oh, come on. Do you really think that the low temperature (compared to near a running engine) and low vibration environment of a glider requires such expensive connections ? Todd 3S Oh come on are you kidding? If you really don't know what you are doing and don't have the right tools then go find a good A&P (or if the aircraft is certified you'll need one to supervise and sign off you work anyhow). I'd argue that doing things properly the first time is not really expensive compared to the cost of downtime, time spend chasing down problems and safety risks. If I only I had a dollar for every mangled piece of glider wiring I've seen... including do it yourself, or certain glider manufactures or occasionally a clueless A&Ps (but most USA A&Ps I've run into seem to have higher electrical wiring standards than many glider manufactueres). Stand around a typical glider port for long enough and you'll hear people complaining about radio reception, battery life, transponder operation or some other electrical problems and when you poke around inside their glider it is often not surprising why. To start with if you are using those cheap single action crimp tools you are probably wasting your time - yes it might work now but the joints are likely not good quality. Crimp connectors need huge pressure to work properly, think swaging metals together to form a surface cold weld not just squeezing the connector enough to mechanically hold onto the wire. You should be using good quality ratcheting type crimpers with the correct die set to suit the connector. There are many reasons to use quality nylon jacketed crimp connectors besides just heat exposure, they are much stronger and the jacket resists slipping off better than with PVC jacketed connectors - and usually the insulators slipping off is cause by damage during crimping (improper/cheap crimp tools again) and/or excessive handling of the wiring. That proper crimp also totally seals the joint against moisture and moisture related corrosion - that can be an issue in gliders stored in humid trailers etc. And keep that soldering iron away from crimp connectors, soldering after the crimp can do damage and pretinning the wire before crimping is very bad. I completely agree on keeping the soldering iron at home - as strange as it may seem at first but properly done crimp connections are more reliable than solder connections, and they are easier to do. Like other have said I would not use anything but Tefzel wire especially in potential abrasion areas such as harnesses that flex when canopies with attached instrument panels move, etc. Tefzel wire does require a special stripper for clean strips, you can get away with a standard high quality stripper at times, but you might be able to borrow Tefzel one from a friendly A&P. Another good source in the USA of Tefzel wire is Stein Air http://www.steinair.com/wire.htm Another reason to use Tefzel aviation wire is it is fully tinned and much more resistant to corrosion than the usual untinned PVC coated junk at hardware/auto parts stores. Darryl |
Wiring a Sailplane | Travis Beach | Soaring | 12 | December 17th 07 08:45 PM |
Wiring a Sailplane | Travis Beach | Soaring | 0 | December 11th 07 05:35 AM |
Q about mic wiring | ken ward | Soaring | 2 | May 31st 05 10:33 PM |
Wiring KX 175 TSO | Tore B. | General Aviation | 0 | May 6th 04 10:02 PM |
Wiring KDR-510 | Chad Lemmen | Owning | 3 | September 16th 03 02:03 PM |
